R56 Things you didn't know about your R56 MINI
Old Aug 12, 2014 | 01:15 PM
  #2851
bmwr606's Avatar
bmwr606
Originally Posted by mattjewell
Sorry I'm at work without the manual, but thanks! I'll check it out.
go here, register and then you can access an obline .pdf of your owners manual
https://ol.miniusa.com/home/login?keepol=true
Old Aug 12, 2014 | 02:24 PM
  #2852
mattjewell's Avatar
mattjewell
Didn't know about this, thanks again!
Old Aug 12, 2014 | 05:38 PM
  #2853
mattjewell's Avatar
mattjewell
Since the radio display isn't displaying correctly because the bulbs need to be replaced, I saw that you can only adjust the level of the speed defendant volume. Can you completely disable it?
Old Aug 12, 2014 | 05:51 PM
  #2854
bmwr606's Avatar
bmwr606
if set to 1 it is not noticeable
Old Aug 12, 2014 | 07:44 PM
  #2855
yesti's Avatar
yesti
I could turn on the heater as well.
Heater doesn't open secondary thermostat. Full cold AC on high fan drops you from 107C to 92C in under a minute.
Old Aug 12, 2014 | 07:45 PM
  #2856
yesti's Avatar
yesti
Originally Posted by daddyandmadi
If you put the a/c on max, it opens a secondary thermostat, dropping the coolant to 90 degrees. The same happens with the sport mode on......
Sport mode only does it with 2013 models. 2013 JCWs always run at 90-95 C
Old Aug 12, 2014 | 08:53 PM
  #2857
Btwyx's Avatar
Btwyx
With our 2103, sport mode only drops the temoperature after its been under load (like an autocross run). The previous years would drop the temperature under load, but then raise it after the load went away.
Interesting about the 2013 JCW, ours runs like the others hot until its under load.
Old Aug 12, 2014 | 08:56 PM
  #2858
yesti's Avatar
yesti
Wish my '12 would run at 90C in sport mode, even if it requires a little spirited driving first. You have an '13 JCW too ?
Old Aug 12, 2014 | 10:04 PM
  #2859
pw4's Avatar
pw4
Originally Posted by fritzo
I love and hate you for this. I tried it from my 3rd floor office window, and it worked! It also started to pour down rain 3 seconds after I did it and there is no way to close it remotely
LOL.
Just check under the carpet beneath the front seats is dry. The control unit for DSC, tire pressures, electronic LSD if fitted and who knows what else is situated there. No, I don't know why. Mine shorted out 2-3 months after carpet got wet, for a $4500 repair bill - the sensor itself is ~$1800.
Old Aug 12, 2014 | 10:15 PM
  #2860
bmwr606's Avatar
bmwr606
my 03/2012 build all4 drops coolant temp if the rpm is held over 4000 ... sport on or sport off
it also drops coolant temp with A/C on, fan speed and recirculation have no effect, only need the A/C to be on
Old Aug 12, 2014 | 10:24 PM
  #2861
bennetbecker's Avatar
bennetbecker
Originally Posted by Rennie
Okay, so on the R56, if you program the car to autolock at 10mph, it will automatically unlock when you turn off the engine. Correct?
Just tested this on mine. My mini auto locks at 10mph and unlocks at shut off.
Old Aug 13, 2014 | 06:18 AM
  #2862
mattjewell's Avatar
mattjewell
Good to know, I'll change that right away.
I figured having it on 6 would be better but I guess not.
Thanks again.
Old Aug 13, 2014 | 08:17 AM
  #2863
bmwr606's Avatar
bmwr606
Thanks again.
I do have mine set to 6 ... I like the feature of auto volume control ... if anything I wish I could get more increase at speed because I run open windows most of the time
Old Aug 13, 2014 | 10:46 PM
  #2864
pw4's Avatar
pw4
I'd like to set mine at 4 if the sunroof's open and 2 if it isn't. :-) BMW engineers did huge amounts of programming but forgot that one.
Old Jul 9, 2015 | 11:40 AM
  #2865
ChefDuck's Avatar
ChefDuck
I made it! WooHoo! *looks around* Where did everybody go?
Old Jul 9, 2015 | 01:39 PM
  #2866
Charlie Victor's Avatar
Charlie Victor
Some of us are still here - check out also Motoring Alliance
Old Jul 9, 2015 | 02:27 PM
  #2867
ChefDuck's Avatar
ChefDuck
Thanks! Will do! 🍻
Old Aug 7, 2015 | 11:39 PM
  #2868
Gearheadaddy's Avatar
Gearheadaddy
Oh yes you can
Originally Posted by dwdyer
No. Neat idea, though. Also the mirrors don't work unless the ignition (I think, maybe just accessory) is on.
Try the Carly app...
Old Aug 8, 2015 | 06:00 AM
  #2869
Bendz's Avatar
Bendz
Recently figured out how to program the turn signal so that when you push it half way up/down it blinks 3 times vs the standard one time. Awesome in traffic.
Old Aug 8, 2015 | 11:07 AM
  #2870
daffodildeb's Avatar
daffodildeb
Each key is programmed separately, so be sure to do your other one, too. That's true of all of the owner programmable options.
Old Aug 8, 2015 | 05:33 PM
  #2871
MyOrangeOne's Avatar
MyOrangeOne
Perhaps this has already been posted regarding cruise control on my F56. Let's say you have the cruise set at 63 mph and you hold the down button just briefly, the cruise will reset to 60. Hitting the down button again it will reset to 55 and on and on. Same thing works for upping the cruise. It is quite useful for me when speed limits change, of course, that is assuming you are following the speed limits
Old Aug 8, 2015 | 06:00 PM
  #2872
daffodildeb
A light touch (up or down) changes 1 mph. A heavier touch should be 5 mph.
BTW, If you have an F56, you're on the wrong thread. This one is for Gen 2 cars (R56). Cruise control works the same, though--it's a typical BMW trait.
Old Aug 8, 2015 | 07:27 PM
  #2873
bratling's Avatar
bratling
Super Moderator
I don't think it's so much the force of touch but the duration. I've had the caps off the circuit boards underneath and they appear to be pretty ordinary membrane switches.
Now that you've given this tip I'm going to have to try it out — I'll try both varying force and duration.
Old Aug 8, 2015 | 08:05 PM
  #2874
daffodildeb
I don't know... It's always been force in previous MINIs, and in Bimmers (my last 4 have had this feature).
If I had my owner's manual we could settle this, but I'm too lazy to walk out to the garage.
Old Aug 8, 2015 | 08:31 PM
  #2875
bratling's Avatar
bratling
Super Moderator
I'm an idiot. I have the 2009 owners manual on my phone and should have looked there first. Here's what it says:
Increasing speed
Press button 3 repeatedly until the desired speed is reached. Every time you press the but-ton, the speed increases by approx. 1 mph or 2 km/h.
Accelerating using the button
Press and hold button 3.
The vehicle accelerates without pressure on the accelerator pedal. After the button is released, the driving speed is maintained and stored.
[b{Decreasing speed [/b]
Press button 4 repeatedly until the desired speed is reached.
The functions here are the same as for increas-ing the speed or accelerating, except that the speed will be decreased.
