R56 EPA Mileage Estimates.
Old Jan 29, 2007 | 09:21 AM
glangford's Avatar
glangford
EPA web site now has posted MPG ratings as official for new 2007. Values are as in press release for manuals. In addition automatics numbers quoted as preliminary are now apparently final. For automatics they are
MC 30/37
MCS 27/34
http://www.fueleconomy.gov/
Old Jan 29, 2007 | 09:59 AM
dwdyer's Avatar
dwdyer
MC 30/37
MCS 27/34
And to save people the click, for manual they are:
MC 32/40
MCS 29/36
Old Jan 29, 2007 | 10:26 AM
JohnBLZ's Avatar
JohnBLZ
It should be noted these are using the 'new' standards to check these...ie real driving conditions as compared to previous years where it was a very generic set of driving conditions..
Old Jan 29, 2007 | 10:27 AM
inomis's Avatar
inomis
What is kind of interesting is the MCS 29/36 is just a tad better than my 1995 Honda Si with similar sized engine, 50 less hp , smaller tires and a few lbs less weight. The MC is probably closer in performance to my old Si and it has way better MPG.
Old Jan 29, 2007 | 11:27 AM
mininovice's Avatar
mininovice
Are these mileage estimates with the "new" formula? If that's the case they are great. For apples to apples I wonder what they would be under last years format if it did indeed change
Old Jan 29, 2007 | 01:32 PM
glangford's Avatar
glangford
I think these are with old estimate methods. New methods don't kick in until 08 model year. Still quite good though. I typically get close to estimated on highway and do a little better than estimated around town, which for me has some highway driving, so I expect the same with my MC when it arrives. If I had ordered a S, however, I might not do as well, just do to driving style.
Old Jan 29, 2007 | 01:38 PM
chrisneal's Avatar
chrisneal
I would think that the fuel economy improvement for the MC will be even better than these numbers indicate, because the EPA's laughable "highway" rating is done at speeds too low to utilize the new overdrive 6th gear.
What I'd really be interested to learn is what the new emissions numbers will be. It's all well and good to improve economy from 38 to 40, but they really have an opportunity to improve upon the mediocre emissions of the pre-2007 cars.
Old Jan 29, 2007 | 01:51 PM
MotorMouth's Avatar
MotorMouth
I don't know the emissions specs, but they are supposed to have improved considerably.
Old Jan 29, 2007 | 02:35 PM
glangford's Avatar
glangford
According to the following
http://www.psa-peugeot-citroen.com/d...1103281940.pdf
If you look on page 21 and 22, the spec sheet for the MC and MCS versions of the engine, the quote the emmision standard as being EU4/ULEV-II. The EU4 is I assume European Union. If ULEV-II is the US spec, that is truly impressive. The tri-tec, is by comparison, a flithy engine. ULEV-II for LDV in US spec is not much dirtier than PZEV. (partial zero emission vehicle). If that is indeed what the link above implies that is really impressive.
Agree with comment about 6th gear. But it will get there pretty quick, depends upon your driving habit. I drove an 06 MCS with 6 speed auto and if driven in lazy fashion, will get to 6th gear about 60 mph, and can cruise around 2K rpm. When you push it though the adaptive nature of the trans will have it wait and get there later. I ordered MC with auto (in port at Charleston!!!) It's gear ratios are different, so I'm not sure what speed and RPM level my experience with 06 MCS will translate to.
madmix
Oct 5, 2015 09:58 AM
Alpha Motoring
Oct 1, 2015 10:30 AM
MiniTigger
Sep 23, 2015 09:17 AM
kjd186
Sep 9, 2015 10:02 AM
