R56 Coolant Leak issue?
Old May 14, 2026 | 02:26 PM
genik's Avatar
genik
Coolant Leak issue?
Its 2-3 days now, that ive noticed a large leak stain (its not oil) in the ground under the hood. Specifically its located under the bonet, in the CoDriver's side. Also when returning home, i got this icon in red color and i could hea -while driving- the car, the fan working continuously. Any ideas what to expect?
Old May 14, 2026 | 02:45 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If there is a coolant leak on the passenger side, then it is likely the water pump seal. And I think that symbol means high coolant temp. Might be time to change the water pump, cross over pipe, and thermostat. How handy are you in the garage?
Old May 14, 2026 | 03:35 PM
genik's Avatar
genik
I also remember that, i had parked the car on a "dodgy" pavement and when i came down from it, i heard a knocking on the minis front underneath area. Is it possible that i might had broken or taken out any pipes that transfer the coolant fluid?
Old May 15, 2026 | 06:15 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
The leak is possibly from the water pump. Check whether the friction wheel turns the water pump pulley when the engine is idling.
Old May 15, 2026 | 10:58 PM
genik's Avatar
genik
I don't know where that is to look for it as I’m not aware of tech stuff. Any video that can help me perhaps?
Old May 16, 2026 | 04:38 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Try to find videos of R56 water pump replacements, and that will get you pointed in the right direction. You will have to go in through the passenger wheel well.
Old May 16, 2026 | 05:38 AM
Maybe, maybe not
Community Builder
Old May 16, 2026 | 08:58 AM
genik's Avatar
genik
Is there some other aftermarket water pump part, that is better quality from the OEM part? What do u think guys?
Old May 16, 2026 | 09:05 AM
Maybe, maybe not
Community Builder
Before buying or replacing any engine parts, you must first identify the precise coolant leak location(s) so that you avoid doing tedious work and installing parts needlessly.
Until the problem is solved, it would be best to stop driving the car because an overheated engine can lead to irreversible damage.
Old May 16, 2026 | 09:56 AM
genik's Avatar
genik
I apreciate what you say, i just want to be ready to get the best parts available and not what the mini shop will want to put. After i got a red icon, ive parked the car staying put!
Btw what kind of irreversible damage are you talking about? :-(
Old May 16, 2026 | 10:10 AM
Maybe, maybe not
Community Builder
Effects of severe engine overheating: dropped valve seats, cylinder head warping and cracking, cylinder bore scoring and piston distortion, engine block warping (main bearing bore alignment), and turbocharger bearing destruction.
Old May 16, 2026 | 10:19 AM
genik's Avatar
genik
I was driving the mini and could hear the fan working but no fluid temp icon would come up. Then when i arrived to my destination and idled while parking the red icon showed up... u think an issue might have been created?
Old May 16, 2026 | 10:23 AM
Maybe, maybe not
Community Builder
It may be a good sign that high coolant temp warning light did not turn on until you stopped and idled engine. How long did you idle engine with the warning light on?
Old May 16, 2026 | 10:32 AM
genik's Avatar
genik
Just 2 secs. As soon as i heard the beeping sound, i turned the engine off.
Old May 16, 2026 | 10:36 AM
Maybe, maybe not
Community Builder
I can't guarantee that there is no engine damage but, based on your information, I feel optimistic for you.
Old May 17, 2026 | 05:58 AM
genik's Avatar
genik
Many thanks, I appreciate your help! Trying to msg u but I am not allowed! 😑
Old May 20, 2026 | 03:25 AM
genik's Avatar
genik
It was the water pump. They put on this and claimed it was OEM. Is GEBA oem?
Old May 29, 2026 | 07:26 AM
giorgos's Avatar
giorgos
Here are some pictures of the factory water pump out of a 2010 N16. There was no manufacturer branding anywhere to be seen. Though the housing was plastic, it was glass fiber reinforced and of much better surface quality/precision than the replacement Dayco.
overheater
R55 :: Clubman Talk (2008+)
Jun 16, 2021 01:35 PM
roll14me
Jul 8, 2014 07:07 AM
Checkmate_2006
Feb 23, 2011 08:07 AM
Northerner
Apr 3, 2010 11:51 AM
harhoosh
Apr 22, 2007 02:41 PM
