R56 PLEASE HELP! Electrical Problem? Car won’t start after parts replaced.
Old May 17, 2026 | 01:56 PM
  #51
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
It appears that you unplugged the volume control valve.
The rail pressure sensor is located below the intake manifold at the center of the fuel rail pointing downward.
If the engine still doesn't start after disconnecting the rail pressure sensor, next check whether you detect an rpm signal while cranking.
https://www.ecstuning.com/b-bavarian...537537319~bav/
Old May 17, 2026 | 02:52 PM
  #52
CapGee's Avatar
CapGee
I believe I found the right one this time with 3 wires (see pictures). Disconnected the fuel sensor and the MAF sensor. Engine cranked but did not start. Got some weird codes on scanner. Fuel pressure sensor code would come on and off. I would clear codes and see some different ones return including MAF and fuel rail pressure sensor. I’m hoping I disconnected the right sensor this time and it was the fuel rail sensor. It was driver side under the coolant tank. I looked at what the sensor looks like if purchased new, and that sensor with power attached looked like the same part. I tried Googling location, but couldn’t find an exact match for 2012 Mini Cooper.
Old May 17, 2026 | 02:56 PM
  #53
CapGee's Avatar
CapGee
Ugh. A light bulb went off as I was typing last message and my brain just thought to look up the refrigerant pressure sensor. It almost looks like the same shape as the fuel pressure sensor. I’m assuming g that’s why I’m now getting a refrigerant low pressure code on the scanner. Back to searching for the fuel rail sensor. 🤦🏻‍♂️
Old May 17, 2026 | 03:04 PM
  #54
Maybe, maybe not
Community Builder
Images in my last post show the location of the rail pressure sensor. Use the colors of the three wires to verify correct identification.
Old May 18, 2026 | 01:37 AM
  #55
CapGee's Avatar
CapGee
Ok. So I finally disconnected the correct fuel pressure sensor. With it disconnected as well as MAF sensor disconnected, I tried to start the car. It cranked but no start. While my scanner does read live data, I cannot find an RPM reading. If it matters, I do see the rpm needle move up a bit when cranking the engine. The pic is what I believe is the fuel sensor.
Old May 18, 2026 | 05:06 AM
  #56
Maybe, maybe not
Community Builder
What are the three wire colors for the connector? With this sensor disconnected, did the previous pressure sensor fault code change?
If your scan tool could read live data, engine speed/rpm data would be found under DME module features.
Detection of rpm needle movement is good news. It means that the crankshaft position sensor likely survived the 7V surge on the DME 5V rail. The finding also suggests that the DME 5V rail is unlikely to be shorted to ground, which would lead to an inoperative crankshaft position sensor.
You scan tool is showing low battery voltage. It's important to maintain the battery at ~12.6V when trying to start the engine and when doing tests.
After the many start attempts, the engine may be flooded (cylinder walls and spark plugs coated in fuel). When you remove the oil dipstick, does it smell strongly of fuel?
Old May 21, 2026 | 11:51 PM
  #57
CapGee's Avatar
CapGee
Maybe the battery is creating some of the issue. I purchased a battery check to see if the battery needs to be replaced. I will update once I get it. See pictures below. I will give each picture a description. Note, after disconnecting fuel rail sensor and MAF, I cranked the engine and no start.
Old May 22, 2026 | 12:00 AM
  #58
CapGee's Avatar
CapGee
Yellow, white and blue wires, hopefully the fuel rail sensor.
After disconnecting fuel rail sensor and MAF, I ran the scanner and received these results.
I cleared the codes and ran scanner again, and got these results.
Same as above (results after clear).
Cleared codes again and tried to start engine. No start and ran scanner. Received this code.
Cleared codes and tried start. Crank but no start. Ran scanner and code popped up.
Cleared codes again. Tried to start and crank only, no start. Ran scanner and these codes popped up.
I was checking to find live RPM readings. This is the menu available for live data.
This is the menu when I go into DME. I don’t see where I can find RPM readings.
Old May 22, 2026 | 05:01 AM
  #59
Maybe, maybe not
Community Builder
Check for engine speed/rpm in Motor Operating Values.
The DME codes suggest that the DME is still healthy.
As you suspected, the two ABS-DSC codes, one IHKS code, and one CAS code are screaming "the battery is two weak!". You can't expect the engine to start without a strong battery.
When you have a strong battery in the car:
1) Keep the MAF sensor and Fuel Rail Pressure Sensor disconnected.
2) Leave a charger connected to the battery for the remaining steps.
3) Turn ignition on (engine off). Look at the battery voltage displayed on your scan tool. Do not proceed until the system voltage reads at least 12.5V+ stable.
4) Clear ALL fault codes from ALL control modules.
5) Read the DME codes before cranking. You want to see only the open-circuit/short-to-B+ codes for those two items, confirming the DME is happy
6) Perform the "Clear Flood Mode" procedure, which shuts off the fuel injectors, keeps the valves moving to pump out excess fuel vapor, and dries the spark plugs.
a. Sit in driver's seat and press the accelerator pedal 100% flat to the floor. Hold it there.
b. Push start button and let engine crank for 5 to 7 seconds with your foot still holding accelerator pedal 100% flat to the floor.
7) Attempt a normal start. Take your foot off the accelerator pedal. Press the brake, and try to start the car normally.
->Engine starts and idles: Let it idle briefly until stable and then shut off. Purchase and install new MAF and Fuel Rail Pressure sensors.
-> Cranks but no start: Immediately use scan tool to retrieve all fault codes, especially from the DME.
Old Yesterday | 11:55 PM
  #60
CapGee's Avatar
CapGee
Sorry it’s been some time. I was traveling for work, and didn’t get a chance to try your instructions above. Are you saying that I should replace the battery before attempting those steps? Or just charge it above 12.5V? I just want to confirm before attempting. Thanks.
Old Today | 06:06 AM
  #61
Maybe, maybe not
Community Builder
If your battery struggles to hold 12.5V after charging it, then have a local auto parts store test the battery. Replace the battery, if necessary. If the battery is fine, connect a battery charger to it during any of your testing procedures to maintain the system at 12.5V.
timjball81
Nov 15, 2025 05:11 AM
trickyrabbit
11
Jan 16, 2025 09:26 AM
Xjsf28
Dec 17, 2019 10:48 AM
gboshell
Dec 27, 2018 11:13 AM
christanaa
Nov 10, 2018 05:57 PM
