R56 Ground strap location
Old May 10, 2026 | 06:24 PM
  #26
DC71's Avatar
DC71
OH, and i forgot. mine is a Seimens. will it matter if the doner cas is a continental?
Old May 10, 2026 | 07:17 PM
  #27
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Can you post a picture of your CAS module that includes all the labels?
Also, have you previously successfully push started your MINI? If so, was it easy to do? I'm trying to figure out the significance of your recent inability to push start your Mini.
Old May 11, 2026 | 04:34 AM
  #28
DC71's Avatar
DC71
I only attempted one push start and it did not even come close to starting. it was more like putting the brakes on than putting it into gear. we were probably not going fast enough.
Old May 11, 2026 | 07:11 AM
  #29
Maybe, maybe not
Community Builder
In thermal failure cases like yours, the issue is rarely a burnt chip. It is usually a fatigued internal relay or a micro-crack in a solder joint that can be repaired. Start by contacting these two reputable companies: The ECU Pro or RPM Motorsports. Prices seem to be around $500-$550.
Note: If The ECU Pro puts your CAS in their heat chamber and it fails to trigger the starter, they will credit the $159 diagnostic fee toward the $350 repair.
Shopping around for other reputable CAS repair services obviously would be wise.
To ensure a successful repair, most repair services require you to send them:
1. Your CAS3 Module
2. At least one working Key Fob to verify the immobilizer handshake.
3. The DME — Optional but recommended to verify that the "secret key" (ISN) matches between the CAS and the engine computer.
javialquim
Jul 13, 2023 07:18 PM
Yoshimura 1
Feb 16, 2021 09:09 AM
Wes13coupe
Oct 24, 2020 05:15 PM
Timmytron
Nov 11, 2017 03:03 PM
sunny cal
Nov 10, 2016 04:00 PM
