R56 No key warning issue 'dead horse'
Old Sep 8, 2024 | 10:45 AM
Mr. J's Avatar
Mr. J
Beating a dead horse but I've searched here on the forum and now I am having the 'no key warning' issue on our 2009 Mini Cooper S. Wife parked it in the driveway (thank goodness it didn't happen somewhere else) and she came back out and got the 'slash thru the key' warning on the screen.
New battery in car in 2023 and it is fully charged via our trickle charger. Fob opens doors and does everything it's supposed to do but when inserted into the dock now we don't even get the slash through the key symbol. Just nothing at all. Fob buttons still open locks and locks door and opens hatch lock. Used Mini only came with one fob.
So... do we need a new fob from a dealer? And if so, which dealer? Are all the dealers going to charge the same? (we are 5 hours from nearest dealer)
thanks!
Old Sep 8, 2024 | 12:26 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
The issue could be either the immobilizer chip or battery in the fob or the CAS control unit that recognizes the immobilizer signal from the fob. I don't think the problem is the fob antenna in the rear view mirror because the fob works on the locks.
It may be worth calling some locksmiths.
Old Sep 9, 2024 | 04:27 AM
Vanski's Avatar
Vanski
@Mr. J ,
Did you re-register your new battery with your OBDII scan tool? You need to do that if you have a square box on your negative battery cable(IBS….intelligent battery system)
Old Sep 9, 2024 | 04:47 AM
Mr. J's Avatar
Mr. J
Originally Posted by Vanski
@Mr. J ,
It’s been running fine since April of 2023 when I installed the battery. Would the problem just now be occurring?
Old Sep 9, 2024 | 06:50 AM
Vanski's Avatar
Vanski
@Mr. J ,
Your battery system can work fine for awhile before it starts acting weird. Did you check the negative cable for that square box?
Old Sep 9, 2024 | 07:17 AM
Maybe, maybe not
Community Builder
Without the trickle charger connected, what voltage do you read across the two battery posts? If battery voltage is good, then watching these three videos may help...
https://youtu.be/JAv0916FDKg?si=hP8mccP5tLpW0I1T
https://youtu.be/GbdCaBKE7Kk?si=JM5hp6B9RvLlFEm2
wcs2021
Jul 27, 2022 12:17 PM
Ta87
Jun 22, 2021 04:51 PM
rpg5553
Jun 20, 2021 03:11 PM
RDemo2
Feb 16, 2012 04:19 AM
jmsamr
Aug 22, 2008 05:00 AM
