R56 2013 base n16 non-turbo should I change the tensioner
Old Nov 12, 2023 | 05:06 PM
jzzach's Avatar
jzzach
We bought this car new late in 2013.
It has 130k miles, and it still has the original timing chain, and tensioner. I recently took it apart to change the TC (out of fear that it was going to break) however , I realized that it was not stretched one bit. I pinned the crank properly and dropped the cam locks with ZERO issues.n Everything fit perfectly.
I did change the plastic guides and the pins, but I put all the other items back in...it truly was not stretched at all.
I am looking for advice on whether or not I should install a new tensioner. The new tensioner seems to be a little bit longer. I don't want to cause an issue, but if the old tensioner is weak from the years and the mileage, it might cause an issue.
I am a religous oil changer using full sythetic. I've changed it every 4k to 5k miles and I extract it as opposed to draining it. Not sure if that has helped me get all these miles out of it or not but I'm sure it hasn't hurt anything. The only issue I've had with this car is the water pipe failure.
Please let me know if you think I should replace the tensioner. Thank you so much.
Old Nov 13, 2023 | 02:21 AM
Vanski's Avatar
Vanski
@jzzach ,
The only time you need to change out the tensioner is:
1) the belt is squeaking like a mouse even after you replaced with a brand new belt and that it still squeaks.
Last edited by Vanski; Nov 13, 2023 at 02:22 AM. Reason: Tnesioner, not friction wheel
Old Nov 13, 2023 | 07:18 AM
jzzach's Avatar
jzzach
Thanks Vanski,
I was referring to the Timing Chain Tensioner, not the belt tensioner. Do you have any knowledge about using a new timing chain tensioner on a 2nd gen mini n16.
Thank you.
Old Nov 14, 2023 | 01:43 AM
Vanski's Avatar
Vanski
@jzzach ,
Ahhh yes......unless your timing chain is clattering while driving up the hill, then yes, It's a good idea to change the tensioner which is actually quite easy to do.
Old Nov 14, 2023 | 05:37 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If you already have the new tensioner in hand, it is maybe a 15 minute task to swap it out. I would do it just for peace of mind.
Old Nov 14, 2023 | 08:36 AM
white46's Avatar
white46
I would replace it.
Old Nov 14, 2023 | 05:04 PM
ptkacik's Avatar
ptkacik
It wasn’t 15 minutes for me. I had to remove the air intake system with air filter etc. I also had to remove the throttle assembly to access the little hose under the air intake bellows. On my R56, the tensioner hits the bellows and won’t come out with it in the way.
Just an FYI,
Peter
PS. I replaced my timing chain at 66,000 miles as my son had driven the car with low oil several times. Fortunately, the chain had not stretched at all and the guides looked nearly new.
Old Nov 15, 2023 | 05:11 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Remove air filter box, then throttle inlet pipe, then tensioner.
Old Nov 15, 2023 | 06:09 AM
ptkacik's Avatar
ptkacik
Right. I couldn’t get the throttle inlet pipe out because I couldn’t get it loose from the hose going to the oil pan. I had to take the throttle body out to gain access to the hose clip.
Peter
The_Harpies
R58 :: Coupé Talk (2012+)
Apr 10, 2022 10:13 AM
fzmanic
May 11, 2020 12:35 PM
wesacosa
Sep 2, 2018 03:05 AM
donniedarko
R55 :: Clubman Talk (2008+)
Jan 18, 2016 06:17 AM
DOC4444
Mar 1, 2015 03:52 PM
