R56 Gas Smell - Ideas
Gas Smell - Ideas
2007 turbo with 120K miles. Recently I have been smelling gas on startup. Car has begun to start harder and idle rough, but runs great above idle. Fuel economy is same as 5 years ago......... Have done some searches, but nothing really conclusive. I would think that as these 2nd gen cars get more miles it would become a common problem and I'd be able to get some suggestions on where to look. Any help would be appreciated.
Not really enough info yet - as other things can cause these symptoms. But "smells" like the HPFP is starting to go ....
https://www.northamericanmotoring.co...ymptoms-3.html
Again - very general and not enough info yet
but those tend to lead to rough rides under load, not at idle .... these symptoms might not cause a code yet
Smells like it coming from firewall area.....but, will check the tank pump and filter as well. Hard to grasp what is causing since it is only on start up and "sometimes" after shut down. Don't smell it driving.
Does anyone have any experience with aftermarket high pressure pumps? I see them from 250 all the way up to 1500.
I believe ECS has a lifetime warranty on their HPFP. Ping them Mike - he is on here a lot and good at responding.
Note - it might not be the fuel pump, as we have limited data. Just saying that it could be. You could replace the fuel filter first - just taking a shot.
I seem to recall an earlie thread where someone discovered a weak solder in the control board, that drove the HPFP, but could not find it. Found the below link btw, which might help. Poster found a bad o ring in the fuel pump assembly that caused some gas smell ...
https://www.northamericanmotoring.co...gnose-diy.html
Yep it falls under the replacement if you bought it from us.
My guess is a connection issue or the line going to the HPFP has a small leak or residue. Check that connection and o-ring, I would wash the lines with soap and water, then dry, then use the old sniff for fuel test.
That trick doesn't work with fluids in the lines, only gasses.
I had a bad HPFP with cel codes and rough start/idle issues, and gas smell. Replaced the pump with one from ECS Tuning (because they have a lifetime replacement). Fixed my start/idle issues, but still had gas smell.
Found out it was a cracked fuel filter housing. Those aren't cheap either though.
Still can't believe I had 2 fuel issues happen at the same time.
Could also be an exhaust leak from the downpipe, which is why you don't smell it when you're moving. I had a small crack in my downpipe and would always smell it if I turn on the air/AC while im going under 15mph or so.
I only smell gas in cabin when parked & with the AC on fresh. Change to recirc & it clears up.
Yep it cuts off the outside air that pulls up near the cowl inlet on the one side near the battery.
ttawfik3
38
Jan 6, 2022 09:25 AM
david_foster
Sep 26, 2019 07:10 AM
