R56 stock wheels with aftermarket longer lug bolts
Old Sep 20, 2023 | 09:08 AM
yyj3869's Avatar
yyj3869
I have stock jcw rims and I think the previous owner used to have spacers on this car before but did not change lug bolts to original. now my car doesn't have spacers but longer bolts like below. would it be okay or do I have to replace all bolts to stock?
Old Sep 20, 2023 | 10:07 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
As long as the bolts aren't too long and rub on the knuckle, you'll be fine with what you have.
Old Sep 20, 2023 | 12:22 PM
yyj3869's Avatar
yyj3869
Thanks for the reply. I believe you are mini expert. this is different topic.
I replaced valve cover yesterday because I found little residue on spark plugs on bottom part but once I removed the valve cover I noticed that there were no spark plug tubes and it seemed spark plug gasket were working fine as you can see the picture below. If I don't have spark plug tube, does it cause oil leak on spark plugs?
Old Sep 20, 2023 | 12:33 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I don't think those tubes (or lack of those tubes) would cause oil on the spark plugs, I would assume only the round gasket at the cover interface would prevent oil from getting in there.
Old Sep 20, 2023 | 01:03 PM
yyj3869's Avatar
yyj3869
Thanks for the explanation. so I don't really need them?
JCWKART
Suspension
Jul 20, 2013 12:54 PM
PA-MCS
Tires, Wheels, & Brakes
Jul 30, 2010 07:08 PM
22CooperS
Apr 11, 2009 06:41 AM
KiLO
May 8, 2005 07:16 PM
goin440
Aug 14, 2003 01:20 PM
