R56 Can front INNER control arm ball joint be replaced?
Old May 21, 2025 | 07:28 AM
  #26
pkgmSu2000's Avatar
pkgmSu2000
Sort of related question… no way to drop the rear subframe without disconnecting brake lines, eh??
Old May 21, 2025 | 07:41 AM
  #27
pkgmSu2000's Avatar
pkgmSu2000
Originally Posted by pkgmSu2000
yep, I’ve got all that Pflex offers for the Mini R57 :-)
ive even got the pivot pin too!
Old May 21, 2025 | 08:11 AM
  #28
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If you already have all that, then why are you asking about increasing NVH with the control arm bushings?!
If you are lowering the rear subframe to install a rear sway bar, then you only have to disconnect the sway bar end links. Shouldn't have to touch the rear brake lines. If you want to pull the rear subframe from the car, then you will have to disconnect everything.
Old May 21, 2025 | 08:21 AM
  #29
pkgmSu2000's Avatar
pkgmSu2000
because im a newbie shade tree mechanic and ask silly questions:-). Thankfully folks like you are so helpful and understanding.
bummer about having to disconnect everything. I wanted to lather POR15 all over the rear subframe removed.
Old May 21, 2025 | 05:23 PM
  #30
pkgmSu2000's Avatar
pkgmSu2000
I hung out at my buddies shop today removing bushings. I never want to do it again.
Old May 22, 2025 | 06:13 AM
  #31
spaktacular's Avatar
spaktacular
I didn't think it was a horrible job. Good thing too, as I have to replace all the rear bushings on the other car this summer
Old May 22, 2025 | 06:18 AM
  #32
Lex2008's Avatar
Lex2008
I've had inner ball joint come out of the control arm 2 times, passenger side on both ocassions. It caused a clunking which pretty hard to diagnose because the joint was not totally pushed out.
I didnt even think they could be R&R'd from the control arm. I thought about welding the balljoint into the control arm...
Old May 22, 2025 | 07:14 AM
  #33
pkgmSu2000's Avatar
pkgmSu2000
hopefully you can… new control arms are $$$
twintert
Oct 30, 2022 10:48 PM
Hairy W Bush
R55 :: Clubman Talk (2008+)
Dec 28, 2017 08:24 PM
RudeJoe
16
Jan 30, 2017 06:41 AM
MeltingPlastic
Suspension
Dec 5, 2016 08:21 AM
JAB 67
Jan 23, 2009 10:49 AM
