R56 2009 MCS Smoke help
Old Sep 15, 2021 | 01:03 PM
Jmoney27's Avatar
Jmoney27
2009 MCS Smoke help
So I picked up a 2009 mcs with 140k on it about a month ago. Drove it about 200 miles home and another few hundred around town with no issues except for a light vibration when braking, looks like it needs new rotors. No biggie. Pulling it into the lower garage it dripped some oil so I put it on stands and got to work.
Long story short I pulled everything apart and replaced the following
-front crank seal
-heat exchanger gaskets
-oil filter housing gaskets/seals
-installed a new vacuum pump
-installed noise maker delete hose
-installed matching intercooler resonator delete hose
Obviously I did an oil/filter change and coolant change while doing all of this.
I have not noticed any leaks since doing the work but I’ve only put about ~200 miles on it since. When I had the down pipe and intake off the turbo did not seem to have any play or signs of oil
Now for the issue. Today I took it for a rip and a few errands. After about an hour of driving and a few stops I was parked with the car idling for about 30 minutes. When I went to leave the lot I pushed the sport mode button and went to take off as I did this I noticed the car was smoking pretty good from the exhaust. It left quite the cloud of what looked like blue smoke and continued smoking a bit until I got on the highway. The smoke went away and I didn’t notice it anymore on the drive home. Parked in the garage and gave it a small rev and it puffed a little smoke.
Before I go crazy thinking about what this may be or spend another 5 hours going through the forum for answers. Does anyone have input on where to start? The car did not smoke at all when I bought it, on the drive home or before it was parked idling for a bit today. I have no clue what it could be but going from no smoke to quite a bit after being parked idling seems odd to me. There was no smoke when I started it up today and I didn’t notice a smell in the cabin when it was smoking.
Only thing on the list to do besides rotors is the water pump pulley. When I replaced the belt and had the crank pulley off I noticed the pulley has grooves in it and seemed to be missing some rubber. New pulley is ordered but I ran the car and watched the friction wheel spin the water pump before driving it. No engine lights or warning lights are on either.
Long post but thanks in advance!
Old Sep 15, 2021 | 01:37 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If the car sat idling for a few minutes, then smoked when you took off, I would suspect PCV system, which means new cam cover. I would replace the hose that goes to the intake manifold, too.
Old Sep 15, 2021 | 01:52 PM
Jmoney27's Avatar
Jmoney27
Cam cover as in the valve cover? Anyway to test this before spending the cash on a new one? Previous owner told me he did a valve cover gasket replacement but didn’t say if he replaced the actual cover or not.
Old Sep 16, 2021 | 08:46 AM
Jmoney27's Avatar
Jmoney27
So I moved the car out of the garage last night and noticed there’s a bit of oil leaking under the passenger side. Looks like the crank seal area but I can’t confirm as the car isn’t apart. Any other things that could be leaking in that area?
Also, no smoke on start up and didn’t smoke at all when I gave it a little rev. These minis are starting to seem like a complete headache
Old Sep 18, 2021 | 12:00 PM
NeonLed's Avatar
NeonLed
Smoke off idle can also be valve seals. With it having 140k I wouldn't doubt if it was them.
Old Sep 18, 2021 | 02:25 PM
Jmoney27's Avatar
Jmoney27
it hasn’t smoked at all since that day. Is there anything that can cause oil to build up while idling but not smoke until I get the engine revving again? As in oil was being burned off of something because the car was idling for a while
Old Sep 21, 2021 | 07:18 AM
heticor's Avatar
heticor
Smoke at idle , generally is due to valve seals. When the engine is at idle, the vacuum produced is the higher. if the valve seal are hard and odes not seal very well allowing oil past to the combustion chamber.
r53-06m6
Dec 21, 2019 02:15 PM
yyj3869
Feb 21, 2018 05:13 AM
jfrankjr
Nov 20, 2017 08:09 AM
indybluer53
Aug 28, 2016 07:25 AM
salastorga28
Aug 10, 2014 07:07 PM
