R56 Issue with car stalling
Old Aug 17, 2021 | 11:30 PM
austin0423's Avatar
austin0423
I have a 2012 mcs and when I first got it it ran good for a while but then it would starting stalling and dying while driving around town. It stalls out almost like it’s running out off gas. After it dies I can restart the car and it’ll run fine for another few minutes before acting up again. Eventually some codes will pop up saying hpfp plausibility and fuel pressure sensor plausibility. I changed the low pressure pump because the old one had broke where the bottom and top connect. I also replaced the fuel filter cuz the car was new to me and has 124000 miles. After replacing those the car ran great for a couple months but now the same problem is happing again. I now suspect the hpfp is going bad is there any way to test this part?
Old Aug 18, 2021 | 02:39 AM
austin0423's Avatar
austin0423
So I codes went away and right now I have the obd scanner hooked up reading the hpfp and the set point value hovers around 5.12 mpa and the pressure reads between 5.06 to 5.21 mpa
thebombardier
Dec 24, 2023 04:09 PM
A94cobra
May 11, 2021 09:35 AM
Thunderclasp
Sep 27, 2020 09:13 AM
user 9276289
Sep 27, 2020 08:21 AM
gresh
Jul 15, 2020 05:37 AM
