R56 Small oil leak under the car - N18 engine
Old May 1, 2021 | 11:32 AM
jncunha's Avatar
jncunha
Hi all,
I recently bought a 2011 Cooper S with the N18 engine. I spent some time trying to check the car for leaks and I couldn't find any apart from the place that you can see marked in the picture below (the picture shows the spot that is now clean):
The oil is not dripping on the floor. It just accumulates a little bit there. I cleaned it with a rag and so far I haven't seen any yet but I haven't drive the car much.
What is causing this and what am I looking at in terms of repair?
Thanks!
Old May 1, 2021 | 03:46 PM
navwizard's Avatar
navwizard
An oil leak from the oil cooler is a common problems on these cars. I just had to do mine. It's not super expensive to do, but is a pita.
The oil cooler is the thing the oil filter goes in, It has an oil side and a coolant side.
https://www.realoem.com/bmw/enUS/sho...diagId=11_4574
That said, it's just a guess from an Internet picture.
Cheers!
Dan
Old May 1, 2021 | 06:55 PM
jncunha's Avatar
jncunha
Cheers!
Dan
Ok thanks. I didn't know this big part was called the oil cooler.
I moved to another country and I'm trying to find a mechanic that can take care of the car from now on.
I hope this doesn't break the bank.
Old May 2, 2021 | 03:47 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If oil is actually dripping from those two weep holes, your rear main seal is leaking. That joint circled in your picture is the mating surfaces between the engine block and the transmission.
You likely won’t notice any dripping unless you drive the car. But, since you have it clean, drive the car a little bit, and check it again to see if it is actually coming from those holes.
If it were leaking from the oil cooler/filter joint, you would see oil dripping around the outside of the casing at that spot. The oil cooler/filter is up the side of the block next to the turbo.
Old May 2, 2021 | 03:52 AM
jncunha's Avatar
jncunha
Ok that makes sense. Before cleaning it I took a look and the oil is coming from the place marked in blue. There wasn’t any other oil running from the top into that spot.
So to my understanding this is something that needs to be taken to the dealer and considering the place of it a lot of disassemble is required and will probably cost me a fortune no?
Old May 2, 2021 | 03:58 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Figure about $1000-1500, since the transmission needs to be removed to access the main seal. One of those things where it makes sense to replace the clutch, since you’re in there. I would keep an eye on it for a little while to try and see how bad it might actually be. Take a drive to the store, and check it again. Park over a drip pan to see how much oil is actually dripping out. If it’s a small amount, and doesn’t seem to be getting worse, then you might be able to let it go for some time. Don’t ignore it, but also don’t think you have to rush out to get it fixed.
Old May 2, 2021 | 04:04 AM
jncunha's Avatar
jncunha
This car is 127k KM now and apparently (according to the previous owner) it got a new clutch at 91k. I wonder if the service was not properly done and now it has a leak.
Before he delivered the car to me he drove around 80 km's to reach my place and I could only see a very small amount of oil "pooled" in that place. I cleaned it with a napkin and so far it's been clean but I only moved the car around in the garage so no serious driving at all.
The car seems ok overall and according to the onboard computer everything is up to date. I just wonder if people can trick it and skip the main service somehow. I would like to be able to check if all the major service it needed so far was done but from 90k-127k it was done outside of official BMW garages.
Old May 2, 2021 | 04:19 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
It’s possible they did the clutch job, and passed on the main seal. Or, they did the clutch and main seal, and either didn’t clean it up after or botched the seal installation.
Like I said, just keep an eye on it. If it stays clean, just motor on!
Old May 2, 2021 | 04:58 PM
S-2013's Avatar
S-2013
Could also be transmission input shaft seal. It would be a weeping from the same place but oil would probably feel a bit thicker to the touch.
Old May 2, 2021 | 08:06 PM
cpmetz's Avatar
cpmetz
This looks like one of the lowest spots. Could be anything. Let me throw the vacuum pump gasket into the mix as well.
Remember hot oil is very thin, and it it could come from up top.
Old May 9, 2021 | 03:36 PM
jwh's Avatar
jwh
The oil cooler leak is common as is a leaking turbo oil line. Both are located on the engine block in front. So easiest way is to remove the bumper cover, bumper, radiator/fan, and the downpipe/cat. assy. Nothing is really difficult about this but it's a fair amount of work. The usual symptom is oil pooling under the front of the engine as well as smoke/smell from oil dripping down onto the exhaust pipe.
What you're showing, however, is the junction between the engine and the clutch housing and your oil, if coming from the weep holes, is likely from the engine rear seal or possibly from the transmission input shaft seal. Either way, a much larger job.
2013_Roadster
Jan 16, 2021 12:44 PM
2013_Roadster
Jan 3, 2021 05:00 PM
Mikescarano
Dec 18, 2018 08:40 PM
Danielng0811
Apr 25, 2014 07:58 PM
Audiophile_Mark
R59 :: Roadster Talk (2012+)
11
Nov 1, 2012 08:38 AM
