R56 Depo Headlight Bulbs
Old Apr 1, 2021 | 01:41 PM
Dmads's Avatar
Dmads
I just got a set of Depo Headlights and I thought they used the H7 bulbs, but these have HB3 9005 ?
I ordered these Ziza H7 Bulbs but I'm not sure they will fit. So I will need the 9005? and does the 9005 have both the High Beam and Low Beam?
Thanks!
Old Apr 1, 2021 | 02:42 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Those headlights should have a shutter inside the projector that opens when you select the high beams. Only need one-beam bulbs.
Old Apr 1, 2021 | 03:28 PM
Dmads's Avatar
Dmads
Should I get LED bulbs?
Old Apr 5, 2021 | 08:49 AM
Yep one bulb and something looks weird, you dont have a clips to hold the bulbs? Like its missing.
Old Apr 5, 2021 | 12:08 PM
Gubi's Avatar
Gubi
Hey Dmads,
If those are the headlights I sold you they definitely take H7 bulbs. Single filament, they use a shutter to switch between high/low.
The bulbs that I sent you installed in them are (rather expensive) 65W H7. Stock Mini halogen headlights are 65W, most H7 bulbs are 55W.
65W H7 bulbs give a bit more light but won't melt the wiring or blind other drivers. I suspect those H7s will give you better light than LEDs and would suggest just using them.
Those projector headlights, when aimed properly, are infinitely better than the terrible OEM halogens.
SiRaDuDe
Dec 10, 2018 07:34 PM
Diaz_13
May 3, 2018 09:40 AM
Thinker2112
Dec 29, 2016 12:33 PM
corcorand
Electrical
Mar 2, 2016 05:35 AM
cdboss
Mar 18, 2015 03:14 PM
