R55 New clutch now grinding when fully depressed
Old Mar 10, 2021 | 05:49 PM
Lazboytt's Avatar
Lazboytt
Hoping someone may know. I just replace the clutch in a 2007 base. Shifts fine. When you press the clutch it’s easy to press but when all the way to the floor it makes a grinding sound. Only happens when fully depressed. I bled the system by depressing the pedal and leaving to the floor for 2 days. Not sure if this means it still has trapped air or if it could be another issue. Drove the car down the street just didn’t push pedal to the floor and it shifts smoothly. Anyone have any ideas what might make the grinding sound when pedal is pushed to the floor?
Old Mar 11, 2021 | 01:12 AM
Staxtis's Avatar
Staxtis
In order to put the air out (if there is) make about 10 full press/depress the clutch without moving any gear...If there is air should come out
Old Mar 11, 2021 | 07:55 PM
NeonLed's Avatar
NeonLed
Might be over extending the pressure plate when you push all the way to the floor. You can buy a clutch stop from bms and make it to your liking. There is a stock clutch stop already pushed into the firewall it might not be there for you anymore or just worn out.
Old Mar 11, 2021 | 08:10 PM
Lazboytt's Avatar
Lazboytt
Thank you for the info
TheDude
Sep 17, 2013 05:38 AM
Porthos
Feb 5, 2012 09:03 AM
TMGRobyn
Feb 23, 2009 07:05 AM
willum
Aug 14, 2007 09:03 PM
myzamboni
Jul 24, 2006 09:42 PM
