R56 how to test charging of key fob?
Old Feb 11, 2021 | 04:02 AM
MotorinMrD's Avatar
MotorinMrD
Hi. I replaced the battery in my R56 FOB. I'm pretty sure I did a good job without damaging anything. The battery lasted about a month. Now it's dead. Anyone know how to tell if it has to do with the induction charger? It looks like my only other idea is to replace the battery again, and see if the same thing happens.
Anyone know if an induction phone charger will work on the FOB?
Old Feb 11, 2021 | 06:35 AM
mrbean's Avatar
mrbean
It's very easy to damage the battery from the heat of the soldering iron. At the factory the tabs are soldered to the circuit board first and then the battery is spot welded on the tabs.
Even though spot welding creates a higher temperature than soldering, the heat is concentrated into such a small area and dissipates so quickly that it doesn't make its way into the battery where it can cause damage.
Old Feb 11, 2021 | 11:18 AM
MotorinMrD's Avatar
MotorinMrD
Thanks for the reply. I will be replacing the battery again. I'll also add that I'm pretty good with a soldering iron. The battery I used had the leads spot welded, so I only soldered the tabs to the board. I think I was pretty careful so as not to put too much heat into the system. I'll try to be even more careful next time
Old Feb 11, 2021 | 01:42 PM
mrbean's Avatar
mrbean
Use leaded solder and tons of flux.
Counterintuitively, use the highest setting on the iron. This will heat the area of interest faster which means there's less time for heat to conduct into the battery.
vetsvette
3rd Gen FAQs
Jan 1, 2020 04:20 PM
bimpower
Aug 31, 2012 02:28 PM
mooo
Jul 20, 2009 11:37 PM
maximus96
Jun 15, 2009 06:53 AM
ucbrother
Apr 7, 2008 10:47 AM
