R56 Water pump pulley done. Torque for upper engine mount? (4 bolts)
Old Dec 18, 2020 | 06:28 PM
Mark_SF's Avatar
Mark_SF
Hello,
I just got done changing the water pump pulley and drive belt. I had to undo the four upper bolts for the engine mounting, to lower that end of the engine enough to reach the 3 bolts on the pulley.
Now I find that my Haynes manual has nothing on the correct torque settings. Does anyone know the torque? Thanks!
Also, the pulley was very tricky. The water pump itself looks like a nightmare! Glad it was just the pulley (for now).
I spent some time messing with a pry bar to release the belt tensioner, before realizing that it's much easier if you have a 30mm wrench, and do it from above. The Pelican Parts write-up neglected to mention this.
Old Dec 19, 2020 | 02:41 AM
Jason Cornelius's Avatar
Jason Cornelius
https://www.bmwrepairguide.com/mini-...er-all-models/
see if that helps. I just swapped my lower engine mount out for a BSH unit, really nice.
Old Dec 19, 2020 | 11:08 AM
Mark_SF's Avatar
Mark_SF
That's great, thank you!
mini4mo
Nov 25, 2024 06:45 PM
minimufuggincoop
Apr 19, 2023 07:42 AM
Nick Royer
Feb 23, 2016 11:11 AM
the whine is so divine
Apr 24, 2008 10:47 AM
MarioKart
Nov 30, 2006 08:29 AM
