R56 Need help with parts
I have what I think is a R56 with N14. It’s a 2008 Mini Cooper S hatchback. It’s got a bad valve. I can’t seem to find a kit to rebuild the cylinder head or do I have to individually buy everything? Need a head gasket kit too. I also wouldn’t mind getting a turbo rebuild kit also. Is there somewhere for a 1 stop shop for this stuff? Car is stock and keeping it that way.
Our NAM vendors have most of the necessary parts, look for one local to you --- ECS, WMW, Pelican, etc. Head gaskets are usually not part of the head gasket kits, and the gasket kits available will contain various gaskets --- you gotta pay attention to kit contents to ensure you get the gaskets you need. Turbo rebuild kits may or may not be available. Due to the high RPM's involved, I wouldn't want to try rebuilding then testing a turbo. Maybe for a stock rebuild, but still risky. Haven't seen any other head kits, strictly individual parts.
Hello,
Here you go: https://www.ecstuning.com/Mini-2008-...s_-and-_Seals/ and https://www.ecstuning.com/Mini-2008-...14B16A/Engine/
On turbos most go with stock Borg warner, which we have full unit. Or they upgrade to JM Turbo Coopers and get a tune.
We have everything you need. But if you have a burnt valve you need to send the head to the machine shop and get new guides and seals as they are likely worn out. If you don't have a machine shop there you can ship it to us as we do those repairs.
I wouldn't buy a "kit" for head rebuild as you will likely end up buying a bunch of stuff you don't actually need, or being short the items you do need.
Make a list and get what you want and need individually as we can supply it all.
https://www.waymotorworks.com/07-coo.../engine-parts/
As for turbo rebuild kits there isn't an option for that just replacement. So if it is good and working you can either reuse it, or sell it as a good used unit and go for a new turbo.
https://www.waymotorworks.com/stock-...8-r59-r60.html
You can also get a new turbo cartridge. Rockauto.com has them in stock $184. More than a rebuild kit...a LOT less than a new turbo. I bought one to re-new my turbo (07s, N14) and it's been great now for about a year.
Austin C. Munford
Aug 12, 2020 02:28 PM
R50/53 ARP head stud kit. Worth it?
KnighTT
Aug 3, 2016 10:02 AM
Apr 19, 2016 04:45 PM
Drivetrain Biulding a head, need help sourcing parts
second to none
Feb 5, 2008 06:04 PM
