R56 help with shifter linkage
Old Dec 5, 2020 | 09:55 AM
Griffsyj's Avatar
Griffsyj
I have a 2008 base with 6speed. Ive had the drivetrain out of it for 7 months and finally got it back in last night. Im trying to hook the shifter linkages with brackets back to the transmission, and I cannot remember how this all pieces together. Does anyone have a picture? All I can find online are the earlier generation linkage pictures.
Yes its been apart for a long time. Bought it with some engine issues, pulled the drive train out to fix it, and then got busy with other projects. Finally got back on it a week or two ago..New timing chain, rebuilt head, clutch, flywheel, all that jazz.
Old Dec 6, 2020 | 11:28 AM
Chernobyl's Avatar
Chernobyl
Here you go - I took some photos of my 2008 Justa shifter linkage. I removed the intake air pipe and brake booster vacuum line, but the rad hoses are still in the way somewhat. Hopefully these show what you're looking for.
Looking towards the firewall:
Looking down on top of gearbox:
Looking forward:
Looking towards the back under the rad hoses:
Old Dec 6, 2020 | 11:34 AM
Lancaster's Avatar
Lancaster
Great pics - I recommend applying with lithium grease or your choice of spray lube to all those connections. Really makes things smooth and buttery!
Old Dec 6, 2020 | 11:42 AM
Griffsyj's Avatar
Griffsyj
Thank you. My main issue was the black square rubber guide fell off and I couldn't remember how it went back on there haha. The car is pretty much back together now, just need to put the axles back in and a few trim pieces.
Old Dec 8, 2020 | 02:27 PM
Griffsyj's Avatar
Griffsyj
Well now I have another issue. The shifter goes into all gears as it should but the transmission itself is not engaging any gears. I can put the shifter in any gear and still spin the axles by hand with the vehicle off. Did I put the linkage bracket on the wrong spline to the transmission? If so, how do you know which spline it should be on, all the splines are the same so there is not just one way the bracket can go onto the spline.
Old Dec 8, 2020 | 03:11 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Manual transmission with both front wheels off he ground? Totally normal to be able to spin the wheels even if in gear, especially with an open differential.
Old Dec 9, 2020 | 05:44 AM
Griffsyj's Avatar
Griffsyj
Wow, you're absolutely right. Talk about a brain fart. I cant believe that slipped my mind. Thanks for the reply
Old Apr 30, 2021 | 02:19 AM
Vanski's Avatar
Vanski
Great photo Chernobyl !!!!!!!! Very helpful
spr061
How to
Jan 24, 2014 01:12 PM
OhBe1
Aug 18, 2013 12:48 PM
indygomini
Nov 1, 2007 09:08 PM
