R56 2012 MCS at PA Auto Select
Hello, I'm looking to get back into an R56 and am interested the 2012 British Racing Green Mini Cooper S at PA Auto Select: http://www.paautoselect.com/used-inv...SV3C55CTY28094
Does anyone know the previous owner of this car and can share their username? Has anyone looked at this car and is willing to provide feedback on why they passed on it?
Thanks,
Joe
Thanks,
Joe
Joe, I don't know the answers to your questions. If I may, I would like to offer some thoughts. Otto's looks to have serviced it regularly over the years. Although, records of oil changes are slim. The owners likely just had it done somewhere else as they were taking good care of it in servicing it at Ottos. From the pics the car looks nice.
As you may already be aware, as this evidently this will not be your first R56, there are several common mechanical gremlins at this age and mileage that appear to inflict great frustration on unsuspecting owners. First, the cooling system. ECS now packages everything in one unit - water pump, coolant pipe, thermostat housing, associated seals and O-rings. As all of these fail seemingly with in days of one another - do it all at once. Secondly, the oil seals. Primary offenders are the crank case oil seal, the oil pan gasket, valve cover gasket and the oil filter housing gasket. Finally, the dreaded timing chain, chain guides, tensioner and seals.
Of course all the above does not include common wear and tear items: Shocks and struts, also due at this time, brakes, rotors, tie rods, and various bushings.
I would recommend that without clear documentation of many of these items being addressed, you either look for another car or use the above as justification for a significant price reduction.
Aa few more thoughts if you do not mind:
Front bumper to hood gap is way off on both sides.
Poor fitment or cheap after market piece made to fit.
Rear bumper to body panel gaps are very large as well. Black trim looks coated in high silicone slime - common, I know but you may find dingy grey plastic after a few washes.
The front headlights look to be cheap aftermarket. I would closely check the wiring
I think Laufenn tires are the Walmart economy brand - This plays in well with the other less expensive "upgrades"
Exhaust is hanging low- need new bracket
Interior is nice
Emergency brake is on the 4th or 5th click and needs adjustment.
If you post some pics from the engine bay and underneath, I could likely find finer fodder for fault finding...
Interior is nice
Interior is nice
Interior is nice
I don't think those lights are aftermarket. They look to be the OEM Bi-Xenon headlights, same as I have on my R56.
My car has stock suspension and has the same "rake" in the front as the car in the link.
Front bumper and hood look like they fit ok to me... front bumper was obviously removed to install a bigger front intercooler. Front lower grill is missing. Rear of the car has an RPM sticker, so it might have a stage tune on it. Can't tell if it has an aftermarket down pipe or not. Exhaust does not look stock. In general, looks like it was well taken care of.
I would get in touch with MarioKart with the VIN and see if he has any records of tuning it:
https://www.northamericanmotoring.co...mariokart.html
Good to know - Thanks for the info!
I just checked out your for sale post - your car is priced well! Personally, I'm only in the market for R56s with the N18 engine (2012 - 2013). Good luck with your sale!
swpars
Oct 7, 2011 05:49 AM
