R56 Bad ECU and Leak
Old Nov 8, 2020 | 11:36 AM
EStreeter's Avatar
EStreeter
Bad ECU and Leak
I have a leak in my sun roof that allowed the water to run down my A pillar and destroy my ECU. My question is can I replace it with a used ECU or does it have to be new. Also, I’m not sure where the leak is coming from because I can’t open the sun roof, has anyone else ran into this type of leak?
Old Nov 9, 2020 | 12:05 PM
MiniToBe's Avatar
MiniToBe
You mean the fuse box...if you can find one with the same part number, then you should be ok in terms of coding. The leak usually comes from the sunroof drains and if they're clogged, they overflow pass the roof liner.
rocysuja
Oct 14, 2013 11:53 PM
ortuna
Apr 17, 2010 04:56 PM
2bkalm
Nov 27, 2006 07:16 PM
