R56 Giving smoke on acceleration / reving
Old Aug 7, 2020 | 09:43 AM
Khan Saab's Avatar
Khan Saab
When i rev my engine a light smoke comes out but it is not continuous, and smell of burning oil also comes. For this purpose i did compression test on all cylinders, all look fine, before taking plugs out , i saw bit of oil beside them .
plugs are bit dark.
compression was Almost 220psi on all cylinders, what could be reason of smoke from exhaust ? Smoke and smell of oil !!
Results of compression test.
Old Aug 7, 2020 | 10:14 AM
MVPeters's Avatar
MVPeters
Compression readings look very good, perhaps on the high side?
Those plugs seem to be the correct heat range, 6, but indicate the engine is running rich.
Is the car usually used for short runs?
I think I'd check &/or change the air filter first & then maybe drive with a little more verve!
Old Aug 7, 2020 | 10:37 AM
knt's Avatar
knt
Looks more oily, last time my sparks was that bad and the same symptom to yours one of the piston went.
I wouldn't drive the car hard until you can find the problem.
Have you had any work done it recently?
Problems you have can range from faulty turbo to valve stem seals etc...
Old Aug 7, 2020 | 10:47 AM
renchjeep's Avatar
renchjeep
The plug on the far right in the first pic looks to have oily deposits on it. I would install 4 new plugs and change the oil and filter, maybe go a bit thicker on the oil.
Old Aug 7, 2020 | 02:13 PM
Khan Saab's Avatar
Khan Saab
car is 97k miles driven, dont know of used for short trips, i bought it few days back , compression might not be 100% perfect, i used cheap amazon 20$ Tester , but it serves the purpose.
Old Aug 8, 2020 | 10:26 AM
Minifenrir's Avatar
Minifenrir
Is it possible the car has an aftermarket oil dipstick? Some of the aftermarket ones do not read correctly and maybe the previous owner overfilled on last oil change. Just a thought
Old Aug 9, 2020 | 05:56 PM
Khan Saab's Avatar
Khan Saab
i dont know if the dipstick is after market or not, but it is very annoying, a long spring type thing with pointed metal piece at end. Some jerk designed it . I cant even see level of oil, specially when oil is clean
minitis
Aug 18, 2020 10:27 AM
minitis
May 8, 2020 12:26 AM
fordjacka
Jul 4, 2019 08:50 AM
traildog
Dec 6, 2016 04:51 AM
sho1sho1
Oct 30, 2013 08:17 AM
