R56 Upstream O2 sensor bracket
Old Aug 7, 2020 | 03:50 AM
Way2Fst4U's Avatar
Way2Fst4U
So I let Tires+ work on my car out of need one day (Broke down by work and I needed to go home). Few weeks later I get an 02 sensor error (P2626). I assumed it just went bad and investigated a little further to make sure I ordered the right part. When I looked under there, the bracket was no longer attached, and the sensor wires were resting on the turbo and burnt. Apparently they had to remove it to change the belt & tensioner? In any case...Anyone know the bolt size for that bracket so I can re-attach it when my new sensor gets here?
Old Aug 7, 2020 | 05:09 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I'm having a hard time figuring out which bolt and bracket you are referring to? Looks to me like the O2 sensor cable just clips onto the cam cover and dip stick bracket:
Old Aug 7, 2020 | 05:24 AM
Way2Fst4U's Avatar
Way2Fst4U
There's a bracket under there that the end of the plug slides onto that's bolted to the block.
J Free
Apr 16, 2017 08:49 AM
amp24680
May 8, 2015 07:06 PM
northbarts
Feb 24, 2013 12:31 PM
kmckmc
Dec 21, 2011 10:03 AM
auscoops
Dec 4, 2008 04:12 AM
