R56 Weird vibration effect through pedals
Old Jan 12, 2019 | 03:06 AM
gex23's Avatar
gex23
So i've had a problem develop on my 2013 R56 JCW which stems back over a year now...
The problem itself is a vibration felt mainly through the pedals / chassis / car itself, and slightly through the steering wheel too, this occurs over a wide speed range but is certainly more noticeable above 75mph. It's Now this translates to a rather obvious vibration / judder through the brake pedal, only when pressing the brake with soft or intermediate pressure, under hard braking I can't feel the vibration much at all.
So far i've done the following in an attempt to cure the problem :
1) Replace all brake discs and pads as the initial thought was warped discs
2) Replace all tyres (michelin PS4s now), in case one tyre had a slight bulge in due to pothole damage
3) All wheels / tyres balanced in case of it being caused by an imbalance
4) Brake fluid changed - during this, I was told that the passenger side front calipers bleed nipple thread has been crossthreaded / stripped at some point in the past, so they couldn't bleed that caliper effectively - could this be causing it?
Also it is in need of tracking but I highly doubt this could cause the above issues.
To finish off, it almost feels as though i'm driving over cobblestones, and this symptom is even at low speeds.
I hope you can help
Old Jan 13, 2019 | 10:43 AM
cyberlunacy's Avatar
cyberlunacy
cold or warm make a difference? outside temp and engine temp?
worse at take off vs. highway speed?
do you notice it parked revving the engine slowly?
Colin Schlagel
Sep 29, 2017 02:29 PM
CARdiac
Dec 30, 2009 09:30 AM
playtowin
Apr 13, 2008 09:54 PM
kyriian
Jan 26, 2007 05:40 AM
slapey
Tires, Wheels, & Brakes
Jul 27, 2005 06:16 PM
