R56 All the strange noises my brand new R56 Cooper S N14 OEM motor makes.
Old Dec 21, 2018 | 02:33 PM
  #51
Lex2008's Avatar
Lex2008
Yep, they just get the extra from bmw group at a better price. ok, if its a problem, send it back, contact our people here for an exchange, We will take care of you. Somethings up with the wheel. We inspect things when they come back and inform BMW group all the time. They will note the batch orders.
I got an RMA and its boxed and ready to send back. That thing caused me so much grief. Ive spent days and days dealing with this issue. I dont want another DAYCO unit....Im traumatized...
Old Dec 21, 2018 | 02:39 PM
  #52
Could be a small batch problem, I had no real issues with the OEM units in the past. My guess is a bad unit on the bearing. Let me know what brand you get on the next one.
Old Dec 21, 2018 | 03:00 PM
  #53
Lex2008's Avatar
Lex2008
Let me get one that works...how about that. Its the OEM-Dayco unit no less. $100.
This is the problem with putting on all new parts at once on an engine. You'd think they'd all work as intended and then something goes awry and you have to start chasing every part you just put on. FREAKING nightmare.
Old Dec 26, 2018 | 12:02 PM
  #54
Wanderlustsrt's Avatar
Wanderlustsrt
Originally Posted by Lex2008
Everything is new. All peripherals are brand new, with exception of the harmonic balancer because it was $300 and its so easy to take off, I didn't wanna waste the money since I knew I could swap it easily at anytime.
That's a very logical question. I'm gonna do that next. Ill have someone raise RPM and I'll listen for it. (duh!)
I'm freaking out thinking about the flywheel being the cause. Having to R&R the flywheel would be a nightmare and hard to swallow considering I just paid for a transmission to be put in AFTER I put in the engine myself. Yes you read that correctly. Trans leaked endlessly right after I put in the new engine. I dont remember hearing that noise when the old trans was in, but it wasnt in for more than a couple dozen miles before I knew I needed a replacement trans.
First you take great videos. I could hear exactly what you were talking about. Second I have an N18 but none of those sounds are familiar (I consider my car very loud at 104K miles). For some reason I would be least scared of the ticking as sounds peripheral.
Old Dec 27, 2018 | 08:03 AM
  #55
Lex2008's Avatar
Lex2008
Frick it, Im just gonna swap in a japanese motor...
Old Dec 27, 2018 | 05:15 PM
  #56
Wanderlustsrt
Thats daring. I often thought the 1.6 to 2.0 honda motors would be cool, hopefully you live in a non emission state. I dont think there have been a ton of gen 2 mini foreign engine swaps, the packaging and fit may be hard, plus all the custom mounts, custom electric hook ups (may be easier just to completely replace the gauges), and needing to figure out a transmission that fits. Someone was doing a chevy swap a while back but not sure what happened to it.
Old Dec 27, 2018 | 06:52 PM
  #57
Lex2008's Avatar
Lex2008
Well I was just kidding. My engine is new. These are just teething pains...I hope.
The noise is much less pronounced with the original and very used friction wheel installed in place of the new Dayco unit, which the mechanic at mini assured me was not an OEM manufacturer. Why mine came in a BMW box is a question for ECS Tuning.. I ordered the Dayco unit because it was cheaper than the OEM unit but not super cheap and of dubious quality.
​​​​​​So I stopped by thet dealershipd and one of the mechanics looked at the car on the lift and can you believe it was making no noise at all. None. Zero. He said the friction wheel had no abnoemal movement. Then after it was off the lift it started making the 'rod knock' noise, albeit very faintly. It could only be heard inside the cabin. The mechanic said it sounded like the friction wheel from inside the cabin.
The water pump pulley looked almost new, according to him, so that's not the culprit. That was changed a few years ago on the old engine.
Anyway he said it wasn't a big deal. Nonetheless I'm not leaving that ancient friction wheel on there either way.
davidmini
Suspension
Apr 16, 2011 09:07 PM
Fracas
Oct 7, 2008 05:12 PM
ocnfi
Oct 28, 2007 03:05 PM
MiniMarki
Dec 6, 2006 12:28 PM
JohnnyOhhh
Jul 19, 2006 10:46 AM
