R56 Throttle Hangs - Diverter Valve?
Old Dec 6, 2018 | 07:53 AM
cloverasx's Avatar
cloverasx
Hey guys, I have a 2012 MCS and sometimes the throttle randomly hangs when I blip the throttle while sitting still. Basically I rev it up to around 2k RPMs and when I let off of the pedal (the pedal isn't sticking, it follows my foot all the way up) and the RPMs hang around 2k. It only lasts for about a second, but it happens infrequently enough that I can't replicate it on a whim. That being said, my upgrades are all bolt-ons and include upgraded intake, bigger intercooler, and a straight pipe exhaust. Outside of removing the CATs, I've done nothing else that should throw a CEL. I don't remember this ever happening before I removed the CATs, but that was the only thing that came to mind as it's the only thing that I've changed that would significantly alter the way the ECU processes how the engine needs to run.
As I mentioned in the title, a thought occurred and as this is my first turbo car I'm not terrible familiar with diverter/BOVs. From what I understand, it's a rubber diaphragm that ends up being a wear item. If it fails, or starts to, it might make sense that it doesn't fully let the air out of the system as it needs to and continues to add air pressure to the engine which may cause it to not rev down. This assumption is literally just that, as I have no familiarity with them, but if any of you guys that have messed with turbos/BOVs before have any input please let me know.
I do plan to get a tune (RPM stage 2 from MarioKart is the plan) once we've paid off a few of our expenses that popped up, and I know that can let the car ignore the lack of CATs but idk if it will fix this hang or make it worse.
Old Dec 6, 2018 | 08:17 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If you are not moving when you "blip" the throttle, its normal - its an emissions thing.
Old Dec 6, 2018 | 08:30 AM
cloverasx's Avatar
cloverasx
Yeah, I've only ever noticed it stationary. I thought it might be dangerous if it happened at a higher RPM while moving, but if that's all it is I won't even worry. Thanks!
t0ad
Jan 30, 2015 02:12 PM
Carmichael
Aug 20, 2013 12:33 PM
rustyeuro
Cooper (non S)
Jul 14, 2011 08:42 AM
jc8899311
Cooper (non S)
16
Mar 11, 2010 11:56 AM
paulmon
Mar 19, 2003 03:12 PM
