R56 polyurethane exhaust hangers r56 s
Old Nov 15, 2018 | 08:57 AM
user 73920's Avatar
user 73920
Hi, im looking for polyurethane hangers for a R56S, it's worth it or not?
Old Nov 15, 2018 | 09:01 AM
cristo's Avatar
cristo
Alliance Member
Don’t see a good reason to do it.
Old Nov 15, 2018 | 04:08 PM
thebombardier's Avatar
thebombardier
Polyurethane has a very low melting point (around 100C depending on mix), plus it is a thermoplastic and will soften as it reaches its melting point. Your poly hangers would probably melt.
Old Nov 15, 2018 | 06:40 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Don't bother the stock rubber ones are perfectly fine and reliable.
https://www.waymotorworks.com/rubber...9-r60-r61.html
Old Nov 16, 2018 | 02:43 AM
user 73920's Avatar
user 73920
So it's useless.
I can't access at your site, anyway, my rubber hangers are fine, in any case, thanks.
Old Nov 16, 2018 | 04:39 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The advantages of urethane exhaust hangers are to limit exhaust movement. I doubt they would be of benefit on the R56.
Old Nov 16, 2018 | 09:31 AM
iwashmycar's Avatar
iwashmycar
If you want to limit movement just rip a big ol zip tie around the rubber ones lol
Old Nov 16, 2018 | 12:24 PM
cloverasx's Avatar
cloverasx
I used a hose clamp around each front hanger to lift up my exhaust to keep it from rubbing before I can get it welded together. Hose clamps can be adjusted too, so they might help with alignment/fitment if you ever have that trouble.
UncDeo
Oct 17, 2014 07:13 PM
MiniMe05
Aug 2, 2006 06:28 PM
fueledbymetal
Sep 6, 2004 01:45 PM
