R56 Oil temp or pressure? For OBD
Old Oct 22, 2018 | 01:54 PM
seamusnh's Avatar
seamusnh
The lake of a temperature gauge in my 07 MCS has always bothered me. Most cars have a gauge. I solved this by getting an OBD device that uses bluetooth to connect to an old cell phone I have and the Torque Lite app. I have it mounted on the dash and can see the engine coolant temperature at a glance.
I'd like to add a gauge for oil pressure or oil temperature. I can get a paid upgrade for Torque, but the gauge only works if there is a sensor for oil (temp or pressure) rather than a switch that just senses a fault and trips an idiot light. Does anyone know if the R56 has a sensor for oil temp or pressure?
Old Oct 22, 2018 | 05:31 PM
Bnourai's Avatar
Bnourai
Not sure but no at least my 09 r56 with dashcomand can not display oil tame nor presur.
Old Oct 23, 2018 | 07:45 PM
seamusnh's Avatar
seamusnh
Thanks, I'll try DashCommand....
Old Oct 25, 2018 | 05:30 PM
mkov608's Avatar
mkov608
I'm using a Scangauge II and I can read oil temp, but not oil pressure. 2011 and newer models have more parameters that are available.
Old Oct 25, 2018 | 06:24 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Sorry on the early N14 cars the Oil pressure isn't on the bus system so you can't read it off the OBD. On the N18 cars the Scangauge can read it off the OBD.
To get oil pressure you'll need to install a real mechanical gauge with a tap to install the sending unit.
https://www.waymotorworks.com/oil-pr...9-r60-r61.html
ostojo
Mar 9, 2022 01:43 PM
genik
Jul 3, 2012 06:12 AM
BChili
Oct 11, 2011 08:53 PM
BoomerMCS
Jul 13, 2011 10:53 PM
fishbulb
Jan 8, 2006 02:30 PM
