R56 seafoam treatment
Old Mar 15, 2018 | 04:16 PM
Noobster's Avatar
Noobster
seafoam treatment
Good day to all,
I am about to do a seafoam treatment to my 2011 MCS (N14 ENGINE) and was wondering if someone had exact instructions on how to do it. I want to clean the combustion chamber and all carbon deposits (heard it had to go in the pcv hose, but how much of the bottle and how slow/fast I have to do it to not blow up my engine ?). was wondering if I had to clean the throttle body too ?
thanks !
Old Mar 16, 2018 | 04:03 AM
thebombardier's Avatar
thebombardier
Seafoam won't really do much for your engine I'm afraid. Most of the carbon buildup to be worried about happens on the backs of the intake valves, and carbon deposits are hard and gummy. Running some fluid over them won't do much. If you want to clean carbon deposits (assuming you have them), walnut blasting is the only way.
Old Mar 16, 2018 | 10:29 AM
Noobster's Avatar
Noobster
Thank you Thebombardier for your second answer, im starting to feel like you are my mini guru !! My wild guess after some research was that if I pour the seafoam in the PCV valve it would go through the intake manifold and into the intake valves and clean them off since I have only 45000 miles, it shouldn't be that bad.
I would love to have your feedback on this
Old Mar 16, 2018 | 11:11 AM
Noobster's Avatar
Noobster
I heard the best way to get to the valves are brake booster hose or PCV Valve I don't know which one to put It through ? some insight would be highly appreciated !
Old Mar 16, 2018 | 11:19 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Had a Seafoam treatment done on my old BMW 540i, worked to clear a problem.
Some descriptions here http://www.detroittuned.com/sea-foam-n14/ on how to use it on your engine.
Old Mar 16, 2018 | 11:51 AM
Noobster's Avatar
Noobster
Thank you for the answer Minnie ! will do this as soon as I receive the can.
does the pcv hose lead to the intake valves ?
Old Mar 16, 2018 | 12:41 PM
nels415's Avatar
nels415
I followed this youtube video, and I had lots of smoke come out. But to be honest, didn't notice any difference.
Old Mar 16, 2018 | 03:19 PM
thebombardier
https://www.youtube.com/watch?v=3u573pdqgZ4
It's steam. You're literally just evaporating the Seafoam and spewing it out the tailpipe.
Old Mar 16, 2018 | 04:40 PM
jcwcoopster's Avatar
jcwcoopster
+1 on the walnut blasting.
Old Mar 16, 2018 | 06:07 PM
AZdsrt's Avatar
AZdsrt
Another +1 on the Walnut blasting. The carbon is pretty well baked onto the intake valves, seafoam will do little to nothing..
Old Mar 16, 2018 | 10:49 PM
BeardedForever's Avatar
BeardedForever
The seafoam doesn't really stay in contact with anything long enough to clean efficiently.
Old Mar 17, 2018 | 08:50 AM
cornjuice's Avatar
cornjuice
need to pour it in a hot engine.. then let it sit for 40min - 1hr until cool; before starting and burning it out
*also works great in the gas, to help cleanup the injectors and funk that builds up on them! I also use some in my engine oil for the last few hundred miles before an oil change. Since starting with it, ive noticed my oil getting lighter (staying cleaner color) for longer between oil changes.
Old Mar 18, 2018 | 05:51 AM
Noobster's Avatar
Noobster
Ok, so thank you all for your advice. I did a carbon clean and the seafoam treatment and could see a difference in terms of hesitation. it used to bog under full acceleration and now it accelerates smoothly.
However it still feels restricted in high RPM (above 3000). when I accelerate it feels like it doesn't give me full power. I did a straight pipe before and can hear the exhaust much louder.
so when I accelerate past 3000 rpm the sound of the exhaust is meaner than the acceleration itself if you know what I mean.
I have a 2011 MCS with a stage 1 tune and I know it can be faster than that. I narrowed it down to either the catalytic being clogged,
maf sensor or restricted Air flow.
If anyone had the same problem fixed it would be amazing.
Old Mar 18, 2018 | 05:06 PM
jcwcoopster
So you did the walnut media blasting of the valves to de-carbonize the valves?
Old Mar 19, 2018 | 02:14 AM
Noobster's Avatar
Noobster
No no one does this in the part of the globe that I live in !! I did something similar that they call carbon cleaning. they put a hose in the front air intake, coming from a machine that converts air into hydrogen which creates small sparks inside the air channels to clean all the deposits such as carbon ... It made a huge difference on the bog/hesitation I had under acceleration but still the power is not there in high rpm, feels like the engine is restricted !
Old Mar 19, 2018 | 04:36 AM
cyow5's Avatar
cyow5
None of this makes any sense at all. Hydrogen atoms (in the form of water) are a tiny fraction of air (~1%), and converting liquid water to H2 can be done but not from the air like that. Second, spraying H2 on carbon won't cause sparks. Third, you can't pump air into an engine that isn't running since it will have nowhere to go unless you carefully set the engine rotation so you have a little valve overlap. In that case, you're just pushing all the deposits directly into the engine which is very bad. Do you know the actual brand name of the machine or process?
Old Mar 19, 2018 | 04:49 AM
Noobster's Avatar
Noobster
It is what the guy explained me. it may be my English explanation lacking technical words but the machine is called CALAMINE STOP. The car was actually idling during one hour when the machine was working. and every 15 minutes he would rev 3 times to let the deposits out of the exhaust. a little black smoke came out everytime.
Old Mar 19, 2018 | 09:24 AM
speedmob's Avatar
speedmob
1 Hour to disassemble the intake manifold, connect up the vac attachment, and bead blast 4 intake cylinders with the shop vac running. The attachment was $85, box of walnut shells from China Freight another $30? and noticeable improvement in engine performance.
The chem treatments don't do much - several shops in central florida started touting a chemical treatment - fogging something into the intake and letting it idle away, hour treatment, couple hundred bucks, supposed to improve performance, higher fuel mileage, allow you to pass smog checks. The Florida AG shut them down as being nothing more than snake oil.
Clean it the right way and blast it. And run good synthetic oil, change at regular intervals, and install a decent catch can.
Old Mar 19, 2018 | 10:26 AM
Noobster's Avatar
Noobster
He did it straight from the air intake in front of the car. The difference is noticeable !
My question was that even if I did notice a difference in terms of hesitation not being there anymore, at high RPM's the acceleration feels kinda slow like if the engine is restricted in a way. like it has dificulty breathing ? (the car is running perfect otherwise)
what can it be ?
Old Mar 19, 2018 | 10:31 AM
cyow5's Avatar
cyow5
Let's say it opened everything up a little so it now breaths 80% of what it did from the factory. If you ask for less than 80% of peak power, it will be perfectly fine. Only after trying to get more air through than it is capable of (80%-100%) will it choke. This could be entirely what's going on
Oxybluecoop
How to
505
Jun 29, 2020 03:12 PM
Oxybluecoop
How to
23
Sep 30, 2016 08:18 AM
DOC4444
Cooper (non S)
Dec 2, 2011 06:33 PM
DOC4444
Aug 17, 2011 08:32 PM
Chilao
R55 :: Clubman Talk (2008+)
Jul 27, 2011 09:00 AM
