R56 shift link cable
Old Feb 21, 2017 | 04:54 AM
Edmrich's Avatar
Edmrich
shift link cable
not i havent seen a forum about this but is the shift link cable suppose to look like its about to fall off on a 2012 mcs ill try and upload pics later on this situation i think i have?
Old Feb 23, 2017 | 05:10 AM
Post up a pic. I would like to see this and I can help you out.
Old Feb 23, 2017 | 06:58 AM
Edmrich's Avatar
Edmrich
Can't see it to clear but that's the one that is super loose
Old Feb 23, 2017 | 07:09 AM
Edmrich's Avatar
Edmrich
That pic is after i put it back to where its suppose to look
Old Feb 24, 2017 | 02:29 PM
timcluff's Avatar
timcluff
Here is a picture of how it should be setup
Old Feb 24, 2017 | 02:41 PM
Yeps , its on there. They snap on(pretty hard) and should pivot around the ball but not come off with force and no play. The boot on the cable is torn, thats all.
Old Feb 24, 2017 | 03:17 PM
Edmrich's Avatar
Edmrich
Yeah but there's a play also with it being on/off
Old Feb 25, 2017 | 09:58 AM
BMC_Kid's Avatar
BMC_Kid
I've just developed a very difficult to engage shifter. Sometimes it just slides right into a gear and other times it feels as if there is something blocking the shifter from going into a gear. I can get it into gear but I've got to really force it. It is bad enough where my wife can't drive it right now. It is always 1st, 3rd, and 5th gears - all forward never back. Are there rebuild kits for this or is there adjustments to remedy this? Any help appreciated - whether parts identification or adjustment directions.
Old Feb 27, 2017 | 06:43 AM
The Cooper S/ JCW take those two cables. 25117594646 & 25112753808
https://www.northamericanmotoring.co...spd-trans.html
Make sure the cable boot have not let in rust from moisture or something else binding them. Or the shift unit on top. I unpluged my cables up front and made sure they move freely and then greased the pivot points on the exposed 23007602720 Shift Unit Set.
That should narrow it down on which is causing the binding.
