R56 Hood Scoop Question
Old Aug 25, 2016 | 10:00 AM
  #26
Val P's Avatar
Val P
I'm surprised nobody responded to this yet. Any suggestions?
Old Aug 25, 2016 | 10:05 AM
  #27
CougarsRFun's Avatar
CougarsRFun
Originally Posted by Capt_bj
looking at your pictures ....
don't glue (tape) to bubbled paint .....
I'd scrape/sand all the loose stuff off and then clean WELL
in general, before applying with tape you want the surface SUPER clean ... no dust, no dirt ... clean up with rubbing alc' .... many times a product that uses double sided tape comes with some 'wipes' to clean the surface ....
you want the tape to find a super smooth and clean surface
It was answered here.
Old Aug 25, 2016 | 10:20 AM
  #28
Capt_bj's Avatar
Capt_bj
that tape is pretty good so long as it is applied to a very clean and smooth surface. Did it come with a 'prep wipe'? If not I'd clean the area well with regular wash, then rub down with alcohol unless you have a friend who has some of this:
but you mentioned cracking and paint bubbles so I'd sand to get all loose paint off, then smooth with 600 grit ... then clean. And I'd consider a lil superglue on the crack ... smoothing any residue here as well ...
Old Aug 25, 2016 | 10:43 AM
  #29
Val P's Avatar
Val P
Sorry, what I meant to ask was if the double-sided tape was enough to keep it from flying off.
Should i remove the paint off the old scoop too?
Old Aug 26, 2016 | 06:04 AM
  #30
Capt_bj's Avatar
Capt_bj
if the paint is "strong" it is fine to tape to it
but if the paint is lifting .....
Old Aug 27, 2016 | 03:40 PM
  #31
Val P's Avatar
Val P
OK, I just finished placing it. I pushed down as hard as i could and held down for at least 7 minutes.
Take a look at the pics and let me know what you think.
Old Aug 27, 2016 | 03:54 PM
  #32
NEPABob's Avatar
NEPABob
It looks nice. Good Job...
Old Aug 29, 2016 | 08:00 AM
  #33
Looks good.
RudeJoe
29
May 31, 2023 08:01 PM
Mike Miller
Jun 6, 2016 03:51 AM
remotecontrol
14
May 28, 2016 04:45 AM
R56SinMD
May 25, 2016 11:32 AM
cspec
May 24, 2016 07:32 AM
