R56 Help finding correct part number for trunk trim piece
Old Aug 6, 2016 | 01:35 PM
htroberts's Avatar
htroberts
We had a lot of motor oil (about two quarts) spill into the trunk, and have tried repeatedly to clean it from the trim pieces, but they appear to be some sort of porous material, and the oil has soaked in. Anything we let touch the trim ends up contaminated with oil. So I've removed the trim and cleaned up the metal, but I'm having trouble identifying the correct part number for one piece:
The car is a 2009 R56 S coupe, and the trim looks like the lower left piece in this diagram:
http://www.realoem.com/bmw/enUS/show...diagId=51_6136
The VIN decoder says I don't have either option 653 ("hi def radio") or 674 ("Harmon Kardon"), so I would just order #2 from that diagram, but the part from the car has some definite differences from #1 or #2 in the realoem diagram--it has a tab to hold the gas filler release and the insert cover has horizontal tabs, so it looks like the lower left item (#5) in the diagram, but realoem doesn't show a part number for that one.
The current part also has a handy label with original manufacturer (Rieter)information, including what's labeled as a "BMW part number" and appears to be "2 752 373 - 13"
I _do_ have option 493, 'storage compartment package', if that ends up making any difference, and the interior is black.
Thanks in advance if you can help.
Old Aug 8, 2016 | 11:37 AM
3lusive's Avatar
3lusive
This is what I found from a brief investigation on realoem:
http://www.realoem.com/bmw/enUS/part...36&q=2+752+373
Search for that part number and it matches the left trunk trim but the part has been superseded by a new one, 51477262285 (which corresponds to part number 5)
http://www.realoem.com/bmw/enUS/show...36#51477262285
For the R56 pre 2010 the option code for the hi fi stereo (harmon kardon in 2010+) is 6FD so you should look for that and it might explain why your trunk looks like the HK part and not the one you think. Another easy way to tell if you have hi-fi is the tweeters in the A pillars.
Old Oct 25, 2016 | 11:26 AM
htroberts's Avatar
htroberts
I read this the day or so after you posted, and it was very helpful. We do have the Hi-Fi/HK radio, and needed that part. For some reason, the realoem catalog (and the one at the local dealer) seemed to hide the Hi-Fi/HK trim when we put in our serial number.
Anyway, I bought a Hi-Fi version trim, and it matches the original. I realized today I had never said thanks.
So: Thanks!
Old Oct 26, 2016 | 09:34 AM
3lusive's Avatar
3lusive
Glad you got the right part, and happy to help
johntotah94
Jan 20, 2018 11:09 PM
eliseo1981
May 2, 2016 06:44 PM
JWA
Mar 23, 2016 08:37 PM
Wandersen
Aug 5, 2002 12:55 PM
Saphilipps
11
Jul 16, 2002 08:29 AM
