R56 Alta rear sway bar and adjustable endlinks question
When installed the alta rear way bar seems to be a little bit at an angle.
I read the RSB should be parallel to the ground for optimal performance.
Would I need to get adjustable rear end links and make them longer to make the bar parallel?
Any insight appreciated.
Actually i noticed mine is the opposite angle because i lowered my car. I need to figure out how low to adjust the whiteline end links I got to bring it to be parallel
Found this image.
So I figured out I have to lengthen the fronts and shorten the rears since my car is lowered.
I need to do this by the same amount I lowered the car.
Yea, looks like he has the wheel off and its on jack stands.
You need to make the adjustments with the car on the ground, having a 4 post rack (alignment rack) makes adjusting the bar easy with adjustable links.
Detroit Tuned Adjustable End Links
W3IWI
Feb 18, 2004 03:52 PM
