R56 Gas Cover
Old Jun 24, 2016 | 05:22 AM
digitaldagor's Avatar
digitaldagor
Gas Cover
Is it possible to install this on an 2012 R56S:
http://new.minimania.com/part/G2NMX7...al-Replacement
It has a note,
Note: Fuel Lid Door is not applicable for the R56 Cooper S Hatchback and R55 Cooper S Clubman models - they both use the chrome fuel cap in place of the fuel lid door.
But it looks like I can replace the entire assembly and have a flush cover? Wanting to body match the panel.
Old Jun 24, 2016 | 06:18 AM
SomeguyinAZ's Avatar
SomeguyinAZ
I follow someone on instagram and they said they have a base Cooper fuel lid on his r56s. So I'm pretty sure it's possible
Old Jun 24, 2016 | 08:31 AM
ammodave's Avatar
ammodave
You can convert completely to the non-S fuel filler but you'll need the whole assembly not just the outer cover. It's a little tricky to get the old parts off without damaging anything. Do a search before you start. You may be able to find the parts used from a non-S owner who converted to the S gas cap.
Old Jun 24, 2016 | 08:33 AM
digitaldagor
I found this guide: http://www.outmotoring.com/images/how_to/Fillercap.pdf
Will definitly keep my eye out for a cooper base assembly on here. I know people like switching to the S style. I much prefer the smooth flush lines.
Old Jun 24, 2016 | 08:42 AM
digitaldagor
I searched mini mania but am not able to find the part. I found the door cover part. But not the assembly. Anyone know the part number?
Old Jun 24, 2016 | 03:52 PM
Mini Mania's Avatar
R56 Gas Cover
Hi digitaldagor:
Mechanically you should be able to interchange the gas cap assembly between Cooper and Cooper S models.
Caution: the gas cap assembly is the same for Hardtop and Clubman. There is a different assembly for Convertible, Coupe, and Roadster. Hope this helps!
WrenchMonkey
May 14, 2016 01:25 PM
gerry2153
Mar 31, 2016 07:23 PM
cargusjoh
R55 :: Clubman Talk (2008+)
Mar 17, 2016 12:18 PM
Drumsound
Mar 17, 2016 05:36 AM
Chimchim
29
Aug 4, 2002 09:02 PM
