R56 2008 Mini Cooper S Won't S after checking fuses
Old Jun 16, 2016 | 11:30 AM
roger951z@gmail.com's Avatar
roger951z@gmail.com
Hello, everyone. My mini cooper does not start. It was working just fine until I checked the fuses because my stereo would not turn on. Now the car won't turn on. All I hear is a clicking sound coming from the fuse box.
Old Jun 17, 2016 | 12:03 PM
nkfry's Avatar
nkfry
Have you tested the battery?
Is the car a manual? Did you accidentally kick the clutch safety switch off the pedal? That would cause a no start.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jun 17, 2016 | 12:50 PM
roger951z@gmail.com
I checked the battery and it was slightly under. And the switch seems to be connected. I currently have my mechanic testing the starter
Old Jun 17, 2016 | 01:20 PM
nkfry's Avatar
nkfry
I doubt you need a starter, they aren't a common failure on these cars. I would say you've got other electrical gremlins going on.
How did they test the battery? And what were the resulting numbers?
Phone:586-792-6464
Old Jun 18, 2016 | 04:43 PM
roger951z@gmail.com
It read 11.50 Volts. I also noticed when I was checking the fuses one of the relays was hot.
Old Jun 20, 2016 | 01:27 PM
ColoCoug's Avatar
ColoCoug
Fuses don't click, so if you hear "a clicking coming from the fuse box" it's not a fuse doing it. However, it could be a relay, since relays have an internal parts which moves, and often makes an audible click. A click is often a clue that there's enough voltage to trigger the relay but not enough to run the device that the relay is supposed to engage.
If the battery is at 11.5 volts with the car off, that battery is depleted and may not have enough power to start the car. I'd throw a battery charger on it, and after you get it charged try again.
Any time a battery is under 12.0V while sitting, it's low and needs to be charged. While running, you should see around 14 to 14.5V across the battery terminals.
AxL_Z
Jul 23, 2016 09:36 AM
S1m0n
Jun 4, 2016 06:37 AM
KevinR
Apr 2, 2016 08:31 AM
Sandijs Shifers
Mar 23, 2016 02:13 PM
JWA
Mar 20, 2016 04:29 PM
