R56 Turn Signals, bottom controls issues
Old May 19, 2016 | 06:53 AM
Ivan1993's Avatar
Ivan1993
I have a 2012 cooper s, I am having some issues with the electronics in the car, after giving it a wash I noticed that some of my electronics were not working.
These include turn signals, windows not going up or down, hazards, high beams, convenience lighting and fog lights. I also have the red mini on a lift icon appear on its own.
I'm assuming there's water damage since everything worked perfectly before.
I have checked all of the fuses, none are blown as far as i can tell. I have done some research and am assuming its a relay or something. I am hoping to find some info on what relay it is, or what the problem could be. Thanks!
Old May 19, 2016 | 07:03 AM
1004ron's Avatar
1004ron
Just so that we have a better understanding, what did this wash entail, .....did you use a pressure washer, and did it include using this in the engine compartment?
Just a regular wash is unlikely to cause those issues.
Old May 19, 2016 | 07:13 AM
cccplus's Avatar
cccplus
Battery might be weak/old.
Old May 19, 2016 | 07:20 AM
Ivan1993's Avatar
Ivan1993
I did wash in the engine compartment not with a pressure washer though. however there was water so I'm assuming it seeped into some electronics.
Old May 19, 2016 | 07:21 AM
Ivan1993's Avatar
Ivan1993
I checked the battery it seems fine. It's less than 4 years old. Thank you though
Old May 19, 2016 | 08:18 AM
1004ron's Avatar
1004ron
I don't have a service manual, but if you could find one to locate the connectors for the engine management and body management units, disconnect them and use a hair drier to dry their connections and apply dielectric grease and reconnect them.
Old May 19, 2016 | 10:04 AM
Ivan1993's Avatar
Ivan1993
I did that, dried everything out still no avail. I'm thinking its the relays in the engine bay. But I have no idea which relays control the windows, fog lights, hazards.
quickcoop
Dec 4, 2020 09:05 AM
JimmyChooToo
Electrical
Jan 24, 2018 09:30 AM
Eurothrasher
May 18, 2016 08:09 AM
JCW_Coupe
Apr 8, 2016 05:46 AM
1004ron
Mar 22, 2016 09:39 AM
