R56 projector f56 style headlight recommendations?
Old May 13, 2016 | 10:25 PM
Tommy Kardinal's Avatar
Tommy Kardinal
I have a 2013 with halogens and am looking to get f56 style replacements. Are the Spyder Projectors (i think these are them: http://www.outmotoring.com/black-hea...5-6-7-8-9.html) the best ones? Is there another brand I should look at? Also are the halogen and Xenon models the same aside from the washer pop out? Thanks in advance, just want to get some answers before dropping $500 on something
Old May 16, 2016 | 12:07 PM
cguzz's Avatar
cguzz
From my understanding if you have halogen currently you will have to get the Spyder halogens. You can retrofit to the xenon but it's expensive!
I put the in the mini 25w xenon on my r56. Nearly $1k but I can see now!
Old May 16, 2016 | 04:03 PM
Tommy Kardinal
Are the halogens and xenon like different connectors or something?
Old May 16, 2016 | 08:43 PM
E36-E46-R56lifewhuuuh?'s Avatar
Did u have to flash the dme or something? Just plug in and get reprogrammed right? Probably worth the money as the halogens are trash.
http://parts.miniofkennesaw.com/prod...wd=&origin=pla
Old May 17, 2016 | 06:29 AM
cguzz's Avatar
cguzz
The xenons require ballast. These have the ballast built in. You will need reprogramming. Mine is a 2009 LCI and a dealer will sell you a new frm module. If you know someone who can code new frm is not required.
I purchased mine from WMW and had him install.
http://www.waymotorworks.com/xenon-h...7-r58-r59.html
Old May 18, 2016 | 01:29 PM
I have the spyder versions on my R58 JCW and the most info here:
https://www.northamericanmotoring.co...adlight-2.html
Great headlights and great projector focus.
Old May 18, 2016 | 04:52 PM
bcriverjunky's Avatar
bcriverjunky
Do the Hi-beams work with these lights?
Old May 19, 2016 | 05:06 AM
Yes,
There is a flap ( like the factory Bi xenons ), for both the Xenons set up and Halogen set ups.
Old May 20, 2016 | 10:58 PM
renchjeep's Avatar
renchjeep
So, ECS, the same bulb provides the light, but there is a moving aperture that covers part of the bulb when in low beam, correct? Is this a dual-filament set-up, or a single, that relies only upon the aperture being moved? Sorry is these are stupid questions. But, here's the deal: If and when I upgrade to your lights, can I use an LED "bulb" to achieve the same cutoff on low-beam, and open it up when high beam is selected, for max lighting? This is my intended route, if so. Thanks in advance.
Old May 24, 2016 | 08:36 AM
Sorry for the delay, just saw this. Yes, just like factory Bi Xenons. Single filament.
You can do an aftermarket LED bulb if you want, its a focused beam on the lows also. . We dont carry them.
Smitha6
Oct 8, 2016 09:30 AM
Gambedegallina
Jun 16, 2016 12:03 AM
fspano118
May 15, 2016 01:17 PM
p8ntbollr
Electrical
May 13, 2016 09:36 AM
only01time
May 10, 2016 10:49 AM
