R56 Oh boy, it's Thermostat time!
Old Jan 7, 2016 | 05:09 AM
  #26
Great, thanks for the update , glad i could help. I am always here if you need something. Work on own MINIs all the time.
Old Jan 7, 2016 | 02:24 PM
  #27
knewsom's Avatar
knewsom
I will never attempt this job again. Absolutely insane.
Old Jan 7, 2016 | 02:25 PM
  #28
it does take some working around. What problems did you run into?
  #29
nkfry's Avatar
nkfry
Awe come on, it's only a 45 minute job.
Once you do over 100 of them it comes natural, you're 1% closer to being a thermostat installation expert. lol
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jan 7, 2016 | 02:27 PM
  #30
When you work on BMW's for over 15 years you are a coolant expert
Old Jan 7, 2016 | 04:04 PM
  #31
knewsom's Avatar
knewsom
Lol, yeah, 1% of the way? Feels like it... Good lord, my first time in the back seat went smoother!
Biggest trouble - the water pipe clip. Lost it a dozen times, had a really difficult time getting it back on. Also had some other issues with getting the wrong parts etc, but mostly it was clearance problems, my big hands, and not having angled needle nose channel locks.
What I'm trying to sort out now is what to do with the second wire that plugs in to the top sensor on the housing. Looks like it adapts to the same plug that is in an aluminum piece in line with a hose that comes out the front of the housing. Do I unplug that and use the new one? Or is there some hidden connector on the wiring harness somewhere?
Old Jan 7, 2016 | 06:36 PM
  #32
knewsom's Avatar
knewsom
Well, I guessed. Plugged in the top sensor to where for forward sensor plugged in to the wiring harness. Check Engine light still on, but I only drove it around the block. Boost works fine. Temps seem fine. Doesn't appear to be dumping coolant, saw a few drips but that's probably from the pools that were left over from the job sloshing out as I drove.
Tried to use my Ultragauge to reset the CEL, no luck - said it was off and there are no codes. ?? Confusing. Hopefully it'll be ok when I drive to San Diego in the morning.
Old Jan 8, 2016 | 05:04 AM
  #33
Pics , for certain year there is an adapter lead, do you have a pic ? Linked you here before, you can see the adapter leads based off month/ year production. Did you order this ?
https://www.ecstuning.com/Mini-2013-...ng/Thermostat/
Old Jan 8, 2016 | 10:54 AM
  #34
knewsom's Avatar
knewsom
OK, it was the temp sensor. Replaces the one in-line with the forward hose. Found out from the dealer today.
How long until the CEL goes off?
Also, what temp should I set my alarm at on the ultragauge? I don't want to overheat and want to be mindful of Temps.
Old Jan 8, 2016 | 11:15 AM
  #35
nkfry's Avatar
nkfry
If the fault has been rectified you should be able to clear the code with you Scangauge, and if the problem isn't persisting the light will stay off.
You can set the temp warning for whatever you want, but your car can see temps in excess of 230* just under normal operation.
The car will let you know when it is unsafe, just keep an eye on the coolant temp if you wanted a hobby to occupy your time while driving.
Phone:586-792-6464
Old Jan 8, 2016 | 11:53 AM
  #36
Figured that was it.
I run 219 to 226 F on the R58 JCW , you can go a bit high on DD. I would set it for like 250 or so.
Cel with go off after you have clear the codes. Should clear with your scan tool.
Old Jan 8, 2016 | 11:59 AM
  #37
knewsom's Avatar
knewsom
I just thought I ought to keep an eye on it since I was just working on the cooling system. Hasn't gone above 226.4.
The light still hasn't gone off. My Ultragauge doesn't show any alarms, pending TCs, and says my heck engine light is off. :/ Getting nervous, dunno why the light is sill on, it's got a brand new thermostat.
Old Jan 8, 2016 | 02:27 PM
  #38
knewsom's Avatar
knewsom
Cheers, good info.
Drove to SD, light stayed on the whole time. Eventually decided to swing by the mini dealer where I bought it brand spanking new and ask them to clear the codes. Welp, they said they had 35 cars ahead of me and couldn't possibly help me out, and I went back to my car all bummed out... Only to fine when I started it up, the light was gone! Yahoo !
Thanks everyone, really appreciate the help.
Old Jan 8, 2016 | 02:32 PM
  #39
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Do note that although your CEL isn't illuminated that the code is still stored in the system. You'll still want to get it cleared so you don't have old codes stored.
888.280.7799 | 6am - 5pm PST
Old Jan 11, 2016 | 05:32 AM
  #40
Cheers, good info.
Thanks for the update.
MiniTigger
15
Jan 8, 2016 05:21 AM
Sho Nuff
Dec 21, 2015 07:55 AM
AFN704
Dec 11, 2015 04:06 PM
b6cool
Dec 11, 2015 02:30 PM
schr5530
24
Dec 9, 2015 08:37 AM
