R56 Shifter stiffnes(manual Trans).R56 base
Old Jun 18, 2015 | 10:14 AM
renl's Avatar
renl
The issue I have with my shifter started out off the blue, one minute it was shifting fine and smooth, the next minute got hard to move and it's very hard to get into third gear All other gears are ok and there are no noises or other problems. I looked inside the shifter cassette and everything looks fine. Is the problem inside the transaxle shifter mechanism?
If anyone has had this issue or knows about it, please help me out.
Thanks.
Rene
Old Jun 18, 2015 | 10:39 AM
Check the lug base connnection of the cable first then the shifter cables on top of the transmission. The shifter cables can bind form rust in the cable and also the nylon busing can stick or separate from the cable end loop hole.
https://www.northamericanmotoring.co...-or-right.html
http://www.realoem.com/bmw/enUS/show...diagId=25_0440
Old Jun 18, 2015 | 02:56 PM
renl's Avatar
renl
Thanks for the info. I'll check those areas as soon as I get a chance.
Old Jun 19, 2015 | 06:59 AM
You are welcome.
Dec 5, 2016 06:31 PM
theblackfalcon
Oct 11, 2015 09:49 AM
cornfly888
Aug 24, 2015 09:57 AM
ki7hy
Aug 12, 2015 07:07 PM
