R56 Stuttering/hesitation after hard accel.
Old Mar 14, 2015 | 04:12 PM
  #26
DOtheDEW's Avatar
DOtheDEW
im not too sure then, maybe swing by the dealer monday morning to grab them, make sure when you install them you torque them down to the correct spec. do no over or under torque them, the car will not run right
Old Mar 15, 2015 | 07:44 AM
  #27
Ghetto Mr Bob's Avatar
Ghetto Mr Bob
So, PepBoys DIDN'T have them in stock after verifying over the phone they did. Customer service blows at that place besides, will not be returning.
Did manage to to get some Denso plugs as a last resort and got them installed. The idle is much improved but I'm still getting P0300 and P0303 CELs. It's consistently those two now. Also getting a B2AAA but I assume that's from the jerkiness causing it to throw the body CEL.
After checking and replacing all 4 spark plugs, cylinder 3 was by far the worst. Just black and sooty whereas the others were more normal-wear-looking.
You guys have any other ideas before I throw in the towel?
Edit: After doing some searching through the forums, I'm starting to wonder about the HPFP. Mini did extend warranty on these, correct?
Old Mar 15, 2015 | 09:56 AM
  #28
Ghetto Mr Bob
A pic of the spark plug from cylinder #3 vs new:
Attached Thumbnails Stuttering/hesitation after hard accel.-img_0320.jpg   Stuttering/hesitation after hard accel.-img_0319.jpg
Old Mar 16, 2015 | 06:12 AM
  #29
Ghetto Mr Bob
Well ladies and gents, had it towed to the local Mini dealer. We'll see where it goes from here.
Old Mar 16, 2015 | 07:09 AM
  #30
Ghetto Mr Bob
Got a call from the dealer, said it was the coil. I'd mentioned to them that I switched coil 3 & 4 and the tech was saying the misfire is now throwing codes for cylinder 4.
I'm a little irked that it didn't throw cylinder 4 code for me, would've been much cheaper and as easy as it gets to replace the coil myself.
Oh well, $200 out the door and got a full diagnostic sweep...could be worse.
Fourflys
43
Oct 20, 2015 09:42 AM
penguinplf
Oct 11, 2015 07:36 PM
navybsn
Oct 4, 2015 03:27 PM
