R56 Help getting door open????
Old Feb 11, 2015 | 07:34 AM
Mini 808's Avatar
Mini 808
I have a 2008 Mini and the dirvers side door won't open neither from the inside or outside. I have read about the cable problem and how to fix it but no one has talk about how to get the door open when neither handle is working??? the lock seems to be working fine it goes up and down. I need to get the door open to get the panel off, it is wegde up against the dash and will not come out. Does anyone know the trick to getting the latch to release????? Thank you for your help.
Old Feb 11, 2015 | 07:52 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
http://www.wikihow.com/Use-a-Slim-Jim ?
Old Feb 11, 2015 | 08:28 AM
Mini 808's Avatar
Mini 808
Thank you for the quick reply.Isn't a slim jim for a lock out. On mine the lock is working fine it's the latch that is not releasing. Will the silm jim work on that problem??? I'm I trying to hook on the cable or something else. LMK Thanks again
Old Feb 11, 2015 | 08:47 AM
Minnie.the.Moocher
Not sure if this is the exact diagram for your car http://www.realoem.com/bmw/showparts...64&hg=51&fg=10 but it looks like part#5 is what you want to move to unlock, unless somehow that came undone from the #1.
I'm no lock expert, but the diagram should help you figure it out.
Old Feb 11, 2015 | 12:35 PM
nkfry's Avatar
nkfry
When you pull on the interior handle does it feel like it has a small amount of resistance, and return to where it should be when released?
If it does, I would be less likely to think the cable is the issue and think your door latch is frozen (assuming you're in a cold climate currently). MINI refined the door actuators in the G2's and the amount of cables popping out of location is nil compared to the G1 cars.
I have also seen salt & road grime buildup in the exterior handles cause issues.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Dieseldoctor
R55 :: Clubman Talk (2008+)
Sep 9, 2015 01:17 PM
HogWldFLTR
Sep 8, 2015 05:25 AM
Filmy
Sep 7, 2015 08:27 PM
dandw2
Sep 7, 2015 11:14 AM
dandw2
Sep 6, 2015 03:14 PM
