R56 Warped rear brake rotors
Old Dec 29, 2014 | 09:20 PM
BrandonM3's Avatar
BrandonM3
This is mostly a post for folks to stumble upon when searching through the archives someday...
I've had a vibration coming through the steering wheel whenever I apply the brakes at 55mph and higher. Right, right, front brake rotors, but that's not the case. I replaced my front rotors and pads, got new tires, and an alignment, yet the vibration persisted. I took the car to the dealer since it's still under the CPO warranty, expecting a faulty control arm bushing or something similar. To my surprise, the culprit was actually the rear rotors having excessive run-out.
I've never had warped rear rotors cause similar symptoms that would be experienced with warped fronts. I'm assuming that because the R56 is so stiff, in addition to being a small chassis in general, the transfer of energy from one side of the car to the other is pretty unimpeded.
TLDR; don't rule out the rear rotors when troubleshooting a vibrating steering wheel when braking.
Old Dec 30, 2014 | 05:15 AM
v10climber's Avatar
v10climber
I'm amazed you were able to warp the rear rotors. Drive for some time with the e-brake on? I'm convinced the rear brakes on these cars are just there for looks
Old Dec 30, 2014 | 09:01 AM
BrandonM3's Avatar
BrandonM3
Nope. We bought the car as a CPO two years ago and it always had that vibration. I just assumed it was the front brakes, and since brakes weren't covered under the warranty, I just opted to deal with it until the front brakes needed replacement. That time finally came two weeks ago, but after replacing them, the problem still existed (though to a slightly lesser degree). I usually replace all four corners at the same time, but for whatever reason, the rears still have a lot of pad life and rotor material remaining. New rear rotors are on the way.
Old Dec 30, 2014 | 09:06 AM
Gil-galad's Avatar
Gil-galad
Originally Posted by BrandonM3
Nope. We bought the car as a CPO two years ago and it always had that vibration...
I'm guessing the previous owners drove with the parking brake engaged at some point. The preexisting condition could have easily slipped past a CPO inspection that lacked the appropriate rigor.
Toolman
Jan 20, 2016 06:50 AM
aldito2
Nov 25, 2015 09:33 PM
jpgwinn24
Tires, Wheels, & Brakes
Aug 23, 2015 02:53 PM
jpgwinn24
R55 :: Clubman Talk (2008+)
Aug 20, 2015 06:57 PM
StealthR53
Aug 8, 2015 10:59 AM
