R56 Has anyone used the MINI Challenge Vented Scoop?
Old Jul 9, 2014 | 08:00 AM
Grizld700's Avatar
Grizld700
I was doing some aimless browsing and came across this scoop:
I wondered, has anyone used this? And how did they like it?
Also at the same site there was the scoop cooling vent:
Any thoughts on either of these? I linked both pictures to the site I found them at.
Old Jul 9, 2014 | 08:11 AM
RobMuntean's Avatar
RobMuntean
Looks nice! I'd do it if I were you.
Old Jul 9, 2014 | 06:40 PM
barnoun's Avatar
barnoun
I remember reading that you have to enlarge the stock hole in the hood to fit the vented scoop. I'd get it if I had the funds, it looks nice on the challenge cars and is functional as well.
Old Jul 9, 2014 | 08:17 PM
Porthos's Avatar
Porthos
I have got the second one there. It is nice but, does not fit the LCI hood without some modification. My mechanic that replaced my hood hacked mine up to make it fit. I wasn't happy about it but, it is too late now.
Old Jul 10, 2014 | 06:13 AM
Grizld700's Avatar
Grizld700
Do you happen to know what part of the hole needed enlarged?
Old Jul 10, 2014 | 08:26 AM
barnoun's Avatar
barnoun
Take a look at this thread on minitorque, it has a picture of the necessary hole enlargement. Its to the layer underneath the scoop.
http://www.minitorque.com/forum/f272...7/index14.html
Old Jul 10, 2014 | 09:00 AM
Grizld700's Avatar
Grizld700
Thanks barnoun!
Old Jul 10, 2014 | 11:12 AM
barnoun's Avatar
barnoun
Old Jul 11, 2014 | 09:56 AM
afadeev's Avatar
afadeev
Originally Posted by Grizld700
I was doing some aimless browsing and came across this scoop: [...]
Also at the same site there was the scoop cooling vent:[...]
What problem does it claim to be solving ?
Does it come in pink ?
a
Old Jul 11, 2014 | 12:53 PM
barnoun's Avatar
barnoun
The vented scoop is to lower under hood temps during racing conditions (it's used on the Challenge cars and the 24hrs of nurburgring Mini Coupe).
I believe the curved cooling vent was used in the Challenge cars before the updated vented scoop was introduced.
Old Jul 11, 2014 | 12:54 PM
barnoun's Avatar
barnoun
It'll be pink if you paint it that color
Old Jul 11, 2014 | 12:56 PM
Ch28Kid's Avatar
Ch28Kid
I am using the scoop cooling vent right now.
It does work. I've done before and after test using a infrared thermometer on the surface tempurature of the hood and turbo oil lines, it is significantly lower. The air actually get push down onto the turbo heat shield and turbo oil lines.
Old Jul 11, 2014 | 01:15 PM
Grizld700's Avatar
Grizld700
How much is significant? If you don't remember hard numbers, an estimate is ok.
Old Jul 11, 2014 | 02:07 PM
Evil4130's Avatar
Evil4130
Vented scoop
FYI if you want to keep engine bay temps down that's ok but using the second part shown above to cool the turbo all you're doing is robbing your self of power. Turbos make the most power when they are red hot and stay at a nominal temp, cooling the turbo is not good, cooling the oil lines not a bad idea but use an oil cooler for that. Just saying.
Old Jul 11, 2014 | 02:35 PM
Grizld700's Avatar
Grizld700
I would suspect the MINI challenge series knows a thing or 2 about racing the MINIs. I don't think they just slapped it. I'm sure there was a process before they got to production level and are now selling it.
Old Jul 11, 2014 | 02:43 PM
jkapinos's Avatar
jkapinos
Yea, but isn't the mini challenge the non turbo cars?.
Old Jul 11, 2014 | 04:08 PM
Ch28Kid's Avatar
Ch28Kid
FYI
The scoop is pushing air to the heat shield, not the turbo. I never said anything about cooling the turbo. The purpose of cooling the oil line is not to reduce EOT but to prevent the lines from getting too hot. The scoop lowers the tempurature of the oil line so oil do get cooked and destroy the o-ring. The oil line is known to leak oil due after millions of heat cycles. That is also why MINI had a recall and added a heat shield on all the N14 engine.
I saw a difference of 30C on the "surface temp" of the oil line and 17C on "surfance temp" of the hood scoop. Your temp may vary depending on where you live.
Engine Oil Temp remains the same according to my gauge.
Just saying...
Old Jul 11, 2014 | 05:32 PM
rkw's Avatar
rkw
It's a modded R56 S: http://www.motoringfile.com/2007/08/...jcw-challenge/
The 1st gen Challenge series was R53: http://www.motoringfile.com/2006/04/...at-snetterton/
Old Jul 16, 2014 | 10:47 AM
barnoun's Avatar
barnoun
a
If you look at the "R56 Super Cooper Jr build" thread on here, you'll see why MINI created the vented hood scoop.
Old Jul 17, 2014 | 06:04 AM
Grizld700's Avatar
Grizld700
+1! Thats exactly why I was looking at both of these options!
Old Jul 27, 2014 | 09:52 PM
bluefox280's Avatar
bluefox280
I manufacture and run a JCW Challenge style vent scoop on my R55:
It keeps ambient air temperature and the front half of the engine bay cooler when in motion; especially during the hotter summers.
Vent scoop shown in front of the OEM aluminum heat shield:
- Erik
Old Jul 29, 2014 | 09:22 AM
mdsbrain's Avatar
mdsbrain
I run this US made challenge style scoop part mentioned above and I feel it has to help the under the hood temps.
http://www.patterndraftimaging.com/p968944062
Old Jul 2, 2025 | 06:54 PM
pkgmSu2000's Avatar
pkgmSu2000
and when it rains?
Old Jul 3, 2025 | 05:03 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Originally Posted by pkgmSu2000
and when it rains?
Everything under the hood is designed to get wet...
Old Jul 3, 2025 | 07:59 AM
pkgmSu2000's Avatar
pkgmSu2000
I see :-)
marendt428
Feb 25, 2016 07:13 AM
Ovrclck
Aug 27, 2015 07:58 PM
O4mcs
Aug 10, 2015 10:22 PM
jrezzo
Aug 9, 2015 10:32 PM
