R56 Interior modification.
My sunroof shade decided it was going to get caught and tear yesterday. The mesh has been an eyesore since day one so now's the time to redo it with some solid black material. Does anybody know the proper procedure to remove the shade on an r56 s? I'll probably also adjust the sunroof so it actually opens when it's really hot out.
Unless you are referring to the fact that it stops at the "cracked" position, and you have to let go and press the switch again to make it fully open...
I don't know the process to remove the sunshade, but I'm curious what you mean by "actually opens" because my sunroof actually opens...
I haven't owned it through a hot summer yet so I haven't experienced that and just haven't seen it posted around. Now I'm going to be upset if mine starts to do that...
I do also have interest in this thread because the mesh just annoys me. If someone knows of an easy removal for the shade, I'm definitely curious about what solution you come up with.
Removing the sunroof shade
Hi,
I had the sunroof shade get jammed and total screwed up on my 2008 R56 S. Turns out you need to remove the sunroof glass, both fro t and back, and replace a cassette which contains the rolled up shade. I looked up the cassette part on www.realoem.com and bought it from Sewell Parts for like $125 or so. When it arrived I looked up in the Bentley manual how to remove the sunroof glass. I don't remember the exact procedure, but I did it fairly easily and without any special tools. I also read up on how to adjust to sunroof glass and did that at the same time.
So, it is all very doable as a DIY and a whole bunch cheaper than having a dealer do it.
Cheers,
Greg
Hi,
Cheers,
Greg
Cheers,
Greg
Ok that makes a LOT more sense. Sorry if I sounded rude or unfriendly. I just realized my initial response could be read as condescending.
https://www.northamericanmotoring.co...-database.html sunroof adjustment TSB can be found here,
I'll add that my R55 had a nasty squeak in the vent position.. really annoying.
Sprayed the lift points on the rear glass with graphite lock lube - FIXED IT!
Oct 1, 2015 12:13 PM
Sep 30, 2015 11:59 AM
Sep 30, 2015 11:46 AM
Sep 30, 2015 11:25 AM
Sep 29, 2015 12:11 PM
