R56 2007 MCS $3000 check engine light
The MINI programming is stuff that allows you to see extra information that the SG can read from the MINI, but does not normally read. If the MINI programming is done, then you have more options for what quantities you can read out on the gauge.
Some MINI-specific places will sell the SG with the MINI programming already done.
If you buy one from someone else, say for instance, on the forum like I did, You can send it to SG and they will install the mini program free. You pay shipping to them, but return shipping is free. Took about 3-4 days from the time I mailed it until I got it back.
Thanks. I just called them and they told me the same thing. What is the programming for the mini?
To tell the truth? Beats the chit outa me. I just sent mine in before I even plugged it in. I'm using it right now for inlet air temp, water temp, boost and volts. When I get my Cravenspeed OBDII boost and water temp gauges I'll change it to something else.
Here ya go---- Mini specific. The "every vehicle" stuff is like MPG (miles per gallon), tachometer, speedometer, time to flame out (I'm an 'ole fighter pilot), throttle position, inlet air temperature, CEL light codes, and a CEL reset capability.
Here is more info on it's capabilities---
I've had one in my motorhome for about 5 years now. I'm waiting for the scan Gauge folks to break into the secret oil pressure code for Mini. If they do, they will give you the codes to reprogram yours over the phone or you can send it back for updates. There are some open fields awaiting a programming code on the "X" gauge.
You can only observe 4 codes at any one time. To see other parameters at any time- you can "push buttons" to observe them.
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Drivetrain Won't hold idle after work performed
Lt. Dan
Aug 10, 2015 08:23 AM
