R56 Recirculating-Air Valve B1214_M_LDR_H
Old Aug 4, 2013 | 05:41 PM
dbrub2's Avatar
dbrub2
2007 R56 99k miles...Yellowhead & DIS diag test gives me the following when running DME test. DME-28AA DME Bypass blow- off valve plausibility- signal implausible - fault currently not present. Recirculating-Air valve B1214_M_LDR_H. The symptom is a yellow check engine light that comes on occasionally but when the engine is restarted the light goes out. it appears to come on after an aggressive maneuver such as a quick lane change which seems to suggest a loose connector or broken wire losing connection. The problem is I'm not sure where to look. As background I replaced the timing chain about 2 months ago and removed lots of the turbo air hoses, etc so I may have caused this symptom. any of you folks got some suggestions/ advice? thx
olson187
Oct 21, 2015 05:25 AM
Fordgt4
Oct 10, 2015 10:42 AM
Southern Marylander
Oct 1, 2015 07:53 AM
Emnotek
Sep 29, 2015 07:37 AM
Nicefeet
Sep 24, 2015 06:53 PM
