R56 Knocking sound from front end?
Old Feb 4, 2013 | 05:30 AM
MellowYell's Avatar
MellowYell
Hi,
I have a 2007 mini Justa with 24k miles. When the engine is cold I hear a knocking sound. This only happens when I turn to the right, which I do everytime I pull out of my driveway. I only occiurs when the engine is cold and only when I make a sharp right turn. Once the engine is good and warm it doesn't happen. Any suggestions?
Old Feb 4, 2013 | 08:02 AM
MellowYell's Avatar
MellowYell
Wow not even any thoughts? Could it be suspension? I do not think it is engine since it involves turning? Maybe something in the steering?
Old Feb 4, 2013 | 11:35 AM
ammodave's Avatar
ammodave
With only 24K mi I wouldn't suspect a CV joint but that's what it sounds like. Have you tried making a sharp right turn with the engine off (coasting) while everything is still cold?
Old Feb 4, 2013 | 12:02 PM
MellowYell's Avatar
MellowYell
Thanks I will try that if it knocks with the engine off it is probably the cv joint right? Should the engine be turned off or just in neutral?
Old Feb 4, 2013 | 09:15 PM
ammodave's Avatar
ammodave
If you're truly trying to remove the engine from the equation, I would think you'd want the engine completely off. Bear in mind you'll lose your power steering and brakes in the process, so find a safe place to try it. Any unusual noise you hear will be from the CV joint or front suspension. Good luck.
boostedhaze
Jan 2, 2018 07:26 PM
silence2-38554
Nov 12, 2015 09:39 AM
gmonde
Sep 8, 2015 06:37 AM
FLYM1N1
Aug 15, 2015 11:20 AM
FatherG
11
Aug 7, 2015 07:49 PM
