R56 Passenger Seat Mat Occupancy Sensor Needs Replacing! :(
Old Oct 16, 2021 | 08:38 AM
  #51
ihate100bees's Avatar
ihate100bees
Originally Posted by Jakomcbean
Find a replacement seat or bottom seat cushion. You can definitely find one cheaper than a new replacement. It doesn't even need to be the same color as long as it has the mat in it. I had this happen to me on a convertible I bought. I managed to find a bottom seat cushion with the sensor mat and heated seat element which I needed for my hardtop. Had to take the seats apart and the C- clip upholstery staples are not a-lot of fun to get off or reinstall but it's doable with some determination. Airbag sensor mat was plug and play no reprogramming needed. Used seats aren't all that hard to find. If I had to do it again I wouldn't hesitate to buy a set of "upgrade" seats. In my case the cushion alone was cheap and was worth a shot. I got lucky. Its easy to see when you get the mat out how the thin film transistor construction can easily be damaged by weight or moisture.
thank you for the response. I've already committed to having the work done at the dealer. Actually I have an appointment this afternoon and the car will be ready by closing time today. I'm under a little pressure because I am driving to Texas in a week with the vehicle. However I think it's great that others will read this post for the future and make their own choice. For me, I'm not sure I would really feel 120 percent comfortable doing the job as I'm not a mechanic but pretty handy on many things. The dealer will reprogram and test everything and make sure everything is 100% working. Also they tell me there will be a two-year . For myself, even though I don't want to spend this much money ($1300), I just feel I have no choice to be 100% sure that the airbag will deploy in case of an accident. The risk was just too high if I try to do it myself. Not saying that someone that does this kind of work everyday can't do the job well, but I don't have the confidence in myself to make sure it would be right. I appreciate the comments here because it does show you that there are other possibilities, that exist. They seem to really have you in their Court when they tell you it needs to be "reprogrammed" (as the manual recommends)... because when you go to any other shop and discuss the repair, they all will tell you that if something needs to be reprogrammed, that they cannot do it because BMW does not give them that information. Anyways thank you so much for the comments. So I will be correcting this problem this afternoon and paying the price for it.
Old Jul 22, 2022 | 08:31 PM
  #52
Josefz2's Avatar
Josefz2
Great thread. I have the 93C3 code which is intermittent, but mostly staying on. I have an ‘08 MCS with 214K miles on it so I’m sure Mini service will laugh at me in regards to the NHTSA 2019 bulletin. I’m going to use Jakomcbean’s advice. I found a 2011 seat on car-parts.com for $225. Hell, I’ve done a lot of work on the pepper white hardtop and have this problem to fix and the comfort access.
Old Aug 12, 2022 | 10:58 AM
  #53
Josefz2's Avatar
Josefz2
Reply to myself and any other interested parties to this thread. I just ordered part #52107498442 which is the seat mat and occupancy sensor for the r56 sport seat. I ordered the part from Seattle Mini. They cross referenced my original part number and it’s been discontinued, most likely due to the recall. The part number I addressed previously doesn’t show up on their website so I ordered over the phone and they gave me their web price of $281. I decided to go this route instead of buying a seat from a wrecking yard. Will update as I replace and see if airbag module needs to be programmed.
Old Aug 24, 2022 | 09:26 AM
  #54
Josefz2's Avatar
Josefz2
Replaced the seat cushion and cover. It wasn’t that hard dealing with the hog rings. I have a new error code 93C5. In googling it seems I need to recode the airbag module. Any suggestions before I cough up the $$ to Mini?
Old Jan 13, 2023 | 08:57 AM
  #55
Just an update, I finally found all the internal part numbers for the Oc3 Sensor fix. Good for people out of warranty and don't want that dang light on.
You used to order the whole seat pad.
R55-R59 MINI Coopers.
Recaro Style Seat:
https://www.ecstuning.com/b-genuine-...o/52107498443/
Sport Seat:
https://www.ecstuning.com/b-genuine-...e/52107498442/
Basic Seat ( no higher lower seat bolster)
https://www.ecstuning.com/b-genuine-...r/52107498441/
Clamps aka hog ties to clamp the seat back
https://www.ecstuning.com/b-genuine-...p/52101945543/
Tool
https://www.ecstuning.com/b-lisle-pa...ier/61400~lis/
Wire straps if needed, long wires that go across under the seat.
https://www.ecstuning.com/b-genuine-...p/52208129296/
Here is the documentation for the NHTSA and the dealer level fix.
https://static.nhtsa.gov/odi/tsbs/20...53778-9999.pdf
If any of the parts are NLA or OOS
Buy the seat bottom with cloth or leatherette or leather option. It will be per VIN and options. Some are available and some are not due to age.
Other options:
Or deactivate: https://www.northamericanmotoring.co...-sensor-2.html
https://www.northamericanmotoring.co...-emulator.html
Get used bottom seat.
Old Jun 7, 2023 | 10:07 PM
  #56
Aloisius's Avatar
Aloisius
Sport Seat:
I'm thinking about doing this, but I'm not sure what seat cushion matches mine. I've got the satellite grey lounge leather on a 2013 Cooper S which looks like:
It looks closest to the sport since it has raised sides, but mine doesn't have the little half circle.
There appears to be a fourth type of seat cushion labeled as a piped seat cushion, but I can't find any pictures of it.
Is this a single clamp or a bag of 100?
Link failed. I think the official tool is https://www.ecstuning.com/b-genuine-bmw-parts/crimping-tool/83300492668/ right?
Old Jun 8, 2023 | 07:19 AM
  #57
Hello,
Let me check on that. I think they are using the sport seat and modifying that bump. MINI only released those part numbers.
Its a single clamp.
Mike
Old Jun 8, 2023 | 07:52 AM
  #58
Ok so lounge leather shows sport seats option, so my guess is that on the back of the fabric/leather side of the original cover then have a filler that continues with that bump. Like the bump is their it just has foam or material on the seat cover that continues it side too side.
Link fixed above for tool
Old Oct 2, 2023 | 03:03 AM
  #59
fladale's Avatar
fladale
I have a 2013 roadster R-59 with a bad air bag occupancy sensor. Did you end up at a mini dealer to get re coded? What tool did you use on the hog rings?
Old Jul 8, 2024 | 11:17 AM
  #60
Update the R55-R59 Sport Seats OC3 pad/sensor just went on back order. You will need to remove the sensor from the pad on another version of the seat and fit it to your original seats.
vr4
Jan 31, 2020 07:53 AM
busterhax
Nov 14, 2018 07:33 PM
Grahams315
May 30, 2013 01:55 PM
Miami
Nov 12, 2012 09:06 AM
1nf3rn0
Electrical
Mar 22, 2007 01:35 PM
