Electrical Deactivating OC3 seat occupancy mat sensor
Old May 3, 2022 | 04:09 PM
  #26
yesti's Avatar
yesti
On my car the seat map connector is all by itself, as shown in your Fig 7 picture, not part of a group of plugs. Maybe it was a LCI change since mine is a 2012 vs your 2008
Old May 3, 2022 | 04:10 PM
  #27
Lex2008's Avatar
Lex2008
ok let me check again.
Old May 3, 2022 | 04:11 PM
  #28
yesti's Avatar
yesti
Originally Posted by Lex2008
Here is your VIN specific harness diagram.
Can you post page #2 of this diagram? That's the one that shows the seat occupancy sensor.
Old May 3, 2022 | 04:20 PM
  #29
Lex2008's Avatar
Lex2008
Is this the one you need? I unbolted the seat...
Old May 3, 2022 | 04:24 PM
  #30
Lex2008's Avatar
Lex2008
Page 2....here ya go:
Old May 3, 2022 | 04:26 PM
  #31
yesti's Avatar
yesti
YES! And your colors match mine! Thanks again for going through the trouble. I can't wait to get that Airbag icon off my dash/speedo. A coworker of mine asked why brown/red/white wires change after the connector and we both decided it was to make life interesting in times like this.......lol
Old May 3, 2022 | 04:29 PM
  #32
yesti's Avatar
yesti
I still dont see why the actual wire colors on the car match with nothing in this schematic. Or am I reading it wrong? Less important now, for sure, just would've saved some wrenching on your part.
Old May 3, 2022 | 04:32 PM
  #33
Lex2008's Avatar
Lex2008
Originally Posted by yesti
YES! And your colors match mine! Thanks again for going through the trouble. I can't wait to get that Airbag icon off my dash/speedo. A coworker of mine asked why brown/red/white wires change after the connector and we both decided it was to make like interesting in times like this.......lol
woohooooooooooooo!!!!
Old May 3, 2022 | 04:34 PM
  #34
Lex2008's Avatar
Lex2008
Well it says NON-OE in the description on ALLDATA. I have no idea what that is intended to mean. The OE diagram is this:
Old May 3, 2022 | 04:38 PM
  #35
yesti's Avatar
yesti
Still dont see purple, grey, yellow. Well I guess yellow is there. Also figured out pin 3 is ground .
Old May 3, 2022 | 05:02 PM
  #36
Lex2008's Avatar
Lex2008
How you gonna fix the connector?
Old May 3, 2022 | 06:30 PM
  #37
yesti's Avatar
yesti
Twisting wires together, black tape. The connector is busted. Code cleared, didn't need the seat belt bypass. Motoring on!
Old May 4, 2022 | 06:23 AM
  #38
Lex2008's Avatar
Lex2008
Living life with wreckless abandon...
Old May 4, 2022 | 09:31 AM
  #39
yesti's Avatar
yesti
Ugh, I found I do need the seat belt chime eliminator. I pushed out a pin in the big connector that faces forward under the seat and it has a female connector. The eliminator has wires with male pins on the ends. So do I need to cut off the pins and solder on the female connectors so they fit in the big connector? That is the question. I emailed support but there is a big time difference and language barrier I'd guess as they were not helpful troubleshooting the seat mat connection.
Old May 4, 2022 | 09:42 AM
  #40
Lex2008's Avatar
Lex2008
I dont understand why joining the wired with electrical tape didnt work.
Old May 4, 2022 | 09:52 AM
  #41
yesti's Avatar
yesti
No, that part worked. There are 2 emulators: seat mat, seat belt buckle. The seat mat (twisted wired/electrical tape) part is working thanks to your help. Now I'm working on eliminating the seat belt chime since the car now thinks the passenger seat is always occupied.
Old May 4, 2022 | 10:14 AM
  #42
Lex2008's Avatar
Lex2008
can you put in a resistor to fool the ECM?
Old May 4, 2022 | 10:16 AM
  #43
yesti's Avatar
yesti
I'm guessing the eliminator box has something similar in it, I haven't cracked it open. I just gotta figure out how to install it since the plugs don't match. I'll watch some youtube videos and see what i'm doing wrong
Old May 4, 2022 | 10:21 AM
  #44
Lex2008's Avatar
Lex2008
so youre saying the ocupancy sensor is broken?
Old May 4, 2022 | 10:51 AM
  #45
yesti's Avatar
yesti
the occupancy sensor aka the seat mat indeed is broken. it was throwing the airbag icon on the dash. that started this whole debacle. the saga continues...
Old May 4, 2022 | 10:54 AM
  #46
Lex2008's Avatar
Lex2008
Ah now I understand. If someone sitting on the seat closes a circuit or increase resistance cant the circuit be easily fooled so the ECM thinks someone is always seated?
Old May 4, 2022 | 11:15 AM
  #47
yesti's Avatar
yesti
apparently its more complicated than that. the emulator box has to produce a digital signal to fool the ECM. It has DIP switches on it to toggle between US/EU spec too.
Old May 5, 2022 | 10:01 PM
  #48
yesti's Avatar
yesti
i can confirm that i am an idiot. of course the female pins on the vehicle side of the seat connector go to male pins on the seat side which i found after watching youtube. i successfully installed the seat belt buckle bypass. all is well now. here is the damage i did to the vehicle side seat mat connector blindly trying to disconnect it when i should've taken 5 minutes to unbolt the seat instead.
Old May 6, 2022 | 06:35 AM
  #49
Lex2008's Avatar
Lex2008
The seatbelt buckle bypass solves the occupancy sensor failure?
Old May 6, 2022 | 09:24 AM
  #50
yesti's Avatar
yesti
when you fix the occupancy sensor, the seat belt chimes for 30 sec or whatever it is after you start driving. the seat belt emulator fixes that part.
