R56 low boost at 4500 rpm
Old Feb 25, 2013 | 04:17 PM
  #26
MNIPWR's Avatar
MNIPWR
The ECU is smart it will learn. Its probably cutting boost because it isn't used to the turbo spooling so fast.
Old Feb 25, 2013 | 07:48 PM
  #27
Thruxton's Avatar
Thruxton
Na no updates man, my techs have been crazy busy, not time to squeeze in my car when there are cash paying customers, LOL. stay tuned tho
Old Mar 6, 2021 | 04:44 AM
  #28
Deano massive's Avatar
Deano massive
More rpm less boost r56 Mini Cooper s
Originally Posted by miniC00PERs
its not internal is it? valves not shut? causing the boost to leak out of the engine, and not hold the compression of the boost? does your boost go up higher, and lower down once u hit 4500 rpms or does it top out boost at 4500 rpm?
so I have this problem. Rocker cover is leaking but not bad. Put a boost guage in and this is what happens...
low Revs it boosts about .5 bar then as it hits about 3k it drops off to minus boost!!
can’t figure out what’s wrong. Only fault code I get and it’s the same all the time is p2177 system to lean off idle bank one 🤷🏼
countrymanman
R60/61 Cooper S Drivetrain
31
Oct 7, 2014 07:07 AM
Drobinson1692
Nov 21, 2011 09:54 PM
dj.papazian
May 8, 2010 11:44 PM
cmcveay
Apr 21, 2010 12:06 AM
iporkgoats
Jan 3, 2010 07:39 PM
